move object in model space while keeping it where it is in paper space?
davesec
hi,
i'm cleaning up some CAD files i was given. in model space everything's on one layer and there's a lot of stuff that overlaps/sits on top of each other.
there are like 50 associated paper space sheets.
is there a way for me to drag these objects out without affecting the viewports in paperspace?
i could probably start putting everything on layers and turning them off, but i generally like to be able to lay everything out so i can see it all at the same time.
thank you!
Theres probbably some smart way but maybe move objects a set distance with ortho on then in your viewport pan the same amount object comes back. It might be something that MACRO record could do.
