Results 1 to 9 of 9
    Senior Member
    AutoCAD 2011
    Jan 2012
    238
    Default Sewer design with Autodesk Storm and Sanitary Analysis ?
    does SSA (Autodesk Storm and Sanitary Analysis) is used for sewer design from scratch ? including the possibility to choose manholes sizes ,interpolate topography, choose pipe diameters and ofcourse createing section along the designed sewer path?
    i once saw this kind of option in autocad civil3d extension and wondered if its the same , because i have a copy of map3d 2013 and its supposed to be a part of the installation .
    thanks
    AARi
    AutoCAD Civil 3D 2013 Documentation. Autodesk Storm and Sanitary Analysis User’s Guide you can have a overview here: scroll down to get ... Autodesk Storm and Sanitary Analysis 2013 User’s Guide (pdf - 17306Kb)
    Code:
    http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=18834231#section10
    AARi
    Super Member Murph_map's Avatar
    Murph_map's Computer Details
    Win 7, Win 8
    HP something or other and the laptop is an HP too
    2 gigs or 6 gigs in Laptop
    Utilities
    Murph_map's Discipline Details
    Boats and campers renting and repairs
    Utilities
    GIS and Map making.
    Map 3D 2016
    Feb 2011
    TN or KY depends if I'm at work or home.
    924
    I haven't tinkered with it in a few years but I would say no, not from scratch. It's more of checking the sizes of the pipes & MH, flow direction/rate as you design in Civil3D. Using in Map3D is for existing systems and not a design tool. It's more of an analyis tool than a design tool.
    Murph
    Need a boat or camper for the weekend?
    Senior Member
    AutoCAD 2011
    Jan 2012
    238
    o.k. i see its not for design , do you know a good software except civil3d for sewers design not expensive simple and fast?
  5. #5
    AARi
    hi here using specific soft. to make calculations [Cype] [diameters+slope studies pipes], the using C3D to make cubic-tearrain studies. have a look here
    Code:
    http://www.hec.usace.army.mil/
    AARi
  6. #6
    Win 7, Win 8
    Utilities
    Utilities
    GIS and Map making.
    Map 3D 2016
    Feb 2011
    924
    Quote Originally Posted by AARi View Post
    Code:
    AARi
    AARI,
    Please use the proper tag to insert links, the tag CODE is meant for program code and not hyperlinks. A lot of browers can not handle the "code" tag properly.
    Murph
  7. #7
    Senior Member
    AutoCAD 2011
    Jan 2012
    238
    anyone can recommend of other software ? maybe an add-on , something like Hydraflow in civil3d.
    thanks again
    *im not from the United-States .
  8. #8
    AARi
    Quote Originally Posted by Murph_map View Post
    AARI,
    i will try this, ie8 & firefox 18 not allow BB code. I supouse you r working in HTML code. In any case i report/ed this to the adm. 4 instruttions-codes. Mey by i am a newbye and i don t have acces to CODE 4 the moment. have no acces to edit m1 post / ? [hr] [mg] [quote] dont mind, i scare coz all my writting is going continuos
  9. #9
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,105
    You can add hyperlinks, just until you reach 10 posts they will need approval. You know this, because I have approved a hyperlink already for you.
    You CAN edit your current posts, just select "Edit Post" at the bottom of your post.
  1. AMEP Piping Wyes adn Sanitary Tees
    By idllc in forum MEP
    Last Post: 12th Feb 2013, 11:29 pm
  2. Sanitary Sewer
    By CivilPrice in forum Civil 3D & LDD
    Last Post: 12th Jul 2012, 06:05 pm
  3. for sewer works
    By askar in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Mar 2012, 03:00 am
  4. Storm and Sanitary Analyst not working on multiple cores
    By loopfish in forum Civil 3D & LDD
    Last Post: 8th Aug 2011, 05:00 pm
  5. Replies: 0
    Last Post: 16th Jun 2011, 10:30 pm
