Results 1 to 3 of 3
    Forum Newbie
    not specified
    Jun 2006
    1
    Default how to draw a spur gear in AutoCAD 2004
    Anyone please tell, how can we draw a spur gear in AutoCAD 2004.
    Senior Member The Nickster's Avatar
    Revit 2015
    May 2006
    Indianapolis, IN
    133
    simple.
    draw one of the teeth of the gear.
    select a radius size of the gear to be.
    "array" the tooth.
    when you type in "array" in the command line it will prompt you for several specifications.
    you want to select polar array, it has a button for you to select a center point and it also asks you to specify the number of items you want to array and what degree to which you want to do this.
    are you wanting to do this in 3d or 2d?
    Forum Newbie rataylor's Avatar
    Multi-disciplinary
    rataylor's Discipline Details
    Multi-disciplinary
    I TEACH BASIC AND ADVANCED MACHINE SHOP
    AutoCAD 2014
    Jan 2014
    MURFREESBORO, TN.
    5
    I have several Youtube vids explaining how to draw gear tooth profiles. later, RT.
    http://www.youtube.com/watch?v=Hvfytr7DuGk
