Toggle layer freeze/thaw
samifox
Here is a simple example:
(defun c:ftog ( / layer l )
   (setq layer "0") ;; Layer to Freeze/Thaw
   (cond
       (   (= (strcase (getvar 'clayer)) (strcase layer))
           (princ "\nCannot freeze the current layer.")
       (   (setq l (tblobjname "LAYER" layer))
           (setq l (vlax-ename->vla-object l))
           (vlax-put l 'freeze (~ (vlax-get l 'freeze)))
       (   (princ (strcat "\nLayer " layer " does not exist.")))
(vl-load-com) (princ)
and Lee...
i excecute your code..
when trying to toggle on i have to regen so the objects re-appear
how can i regenerate in the code?
8) all those starting with vlax
The vlax-ename->vla-object function converts the LAYER entity to a VLA-Object which may then be manipulated using its ActiveX Properties & Methods, rather than manipulating the DXF Group codes of the LAYER entity.
I am then manipulating the Freeze property of the VLA Layer Object using the undocumented vlax-get / vlax-put functions, since these functions return native AutoLISP data types, rather than the Visual LISP :vlax-true / :vlax-false symbols as returned by vlax-get-property or vla-get-freeze.
As for the toggle itself, consider:
_$ (~ 0)
-1
_$ (~ -1)
0
  • 2 years later...
_$ (~ 0)
-1
_$ (~ -1)
0
what did you mean by that Lee ?
