Bill Tillman Posted February 26, 2013 Share Posted February 26, 2013 I have a main program which works on most of the drawing and then loads a separate program when it's needed. I seem to have some kind of problem in that second program but I'm not sure how to toggle a breakpoint in it. I set one and then save it but when the programs run, it just passes right through the breakpoint I've set. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 26, 2013 Share Posted February 26, 2013 my way ...code (Princ "wow1") ...code (princ "wow2") ...code Quote Link to comment Share on other sites More sharing options...
Bill Tillman Posted February 26, 2013 Author Share Posted February 26, 2013 BIGAL, I'm not sure I follow you there. The thing I wish to do is to step through the second program which gets loaded from the first one. The only way I've found around this is to copy all the code of the second program into the first one. Then I can toggle a breakpoint which will allow me to step through the second program. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted February 27, 2013 Share Posted February 27, 2013 Use the 'Break On Error' setting in the Visual LISP IDE to automatically set a break point at the expression at which the code fails, then view the 'Last Break Source' to view such expression. This method is described in my tutorial: Debugging Code with the Visual LISP IDE Quote Link to comment Share on other sites More sharing options...
Bill Tillman Posted February 28, 2013 Author Share Posted February 28, 2013 I'm still having some trouble with this. It's not that the code fails, in fact in runs through without error. But there are some places in the code which gets loaded from the first on in which I want to pause and have a look at some of the variables. Trouble is when I toggle a BreakPoint in the sub-program, even if I save it that way, the program runs right on through. The only way I've found to do this is to move the code from the secondary program back into the main program and toggle the BreakPoints therein. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted February 28, 2013 Share Posted February 28, 2013 Trouble is when I toggle a BreakPoint in the sub-program, even if I save it that way, the program runs right on through Break points are not saved with the program, these are purely a debugging utility offered by the Visual LISP IDE. Quote Link to comment Share on other sites More sharing options...
Bill Tillman Posted February 28, 2013 Author Share Posted February 28, 2013 Thanks again Lee. The break point part I understand. I guess what I'm finding it that in this scenario there seems to be no way to stop the program execution at the point I need. The only way to do it is to merge the two programs into one, set the break point, then run it. Program A is loaded. Inside of program A is a line which loads program B. When program B starts running I want to pause execution at a particular spot to check out a few variables. But there seems to be no way to pause program B unless I merge the text from both programs into a single program and run it as one complete code. Since these chunks of code are multi 1000 liners, it's easier to work with them in separate programs. Makes revisions so much easier. But certain parts of debugging are not possible unless I merge them together and run it as one big program where I can toggle break points which actually pause execution. Quote Link to comment Share on other sites More sharing options...
BlackBox Posted February 28, 2013 Share Posted February 28, 2013 ... The break point part I understand. ... there seems to be no way to pause program B unless I merge the text from both programs into a single program and run it as one complete code. ... certain parts of debugging are not possible unless I merge them together and run it as one big program where I can toggle break points which actually pause execution. Bill, It doesn't matter if the code is in separate files, it matters that you open the file within VLIDE (in this case program B), set the breakpoint where you like, and load that code from the code editor (the code in VLIDE that you've just set the breakpoint). Since these chunks of code are multi 1000 liners, it's easier to work with them in separate programs. Makes revisions so much easier. I do the same thing for each Class in my .NET apps (split them out into different code files within my Solution's Project). I've also done this for one particularly large LISP routine, but not exactly intuitive (the VLIDE), as compared to Visual Studio WRT navigating, etc.. Quote Link to comment Share on other sites More sharing options...
Bill Tillman Posted February 28, 2013 Author Share Posted February 28, 2013 Thanks for the reply Renderman. I wish that were the case.... or I must really be missing something. I open both programs in the IDE and place a break point in program B. I load both of them and then run program A. But when program B runs it just keeps going past the break point. OK so I then comment out the line in program A which loads program B. Load both of them again using the icon in the IDE but the same thing happens. No matter how many break points I put in program B, when it runs it just passes right by them until it's completed, then program A takes over again. If there are break points in program A they are acknowledged and the program pauses. If I'm missing something on this please advise. Quote Link to comment Share on other sites More sharing options...
BlackBox Posted February 28, 2013 Share Posted February 28, 2013 The only reason that I can think of for that to happen (and I could be overlooking something?), is that the code you've opened in VLIDE, added the breakpoint/code modification to is either (a) not being loaded due to an error, or (b) you're mistakenly/unknowingly invoking the wrong command/calling function(s). *off to abuse Autoloader som'more* Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 1, 2013 Share Posted March 1, 2013 Like above for debugging add a line in 2nd program it will display variable value and wait for you to continue, obviously the VLIDE is a better way to go. (princ yourvariable)(setq dummy (getstring)) ; press any key Quote Link to comment Share on other sites More sharing options...
