LaBellaLuna Posted March 2, 2013 Share Posted March 2, 2013 I'm playing around with 2013 (full version) and when I select MOVE (ribbon or "M") the object, as well as everything that it's connected to moves....?? Could someone tell me how to modify this? I can't figure it out! I just want the object I've selected to move! I'm also on an iMac........... Quote Link to comment Share on other sites More sharing options...
dbroada Posted March 2, 2013 Share Posted March 2, 2013 I'm guessing you have implied constraints set. I don't know how to unset it but look constraints up in the help file. Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 2, 2013 Share Posted March 2, 2013 Isn't there a toggle for it at the bottom of the screen? INFERCONSTRAINTS Quote Link to comment Share on other sites More sharing options...
JD Mather Posted March 2, 2013 Share Posted March 2, 2013 Toogle is bottom left. This does not remove existing constraints, only turns on/off creation of automatic constraints. Delete Constraint to remove existing constraints. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted March 4, 2013 Share Posted March 4, 2013 Could also check to see if it is part of a Group or Block. Quote Link to comment Share on other sites More sharing options...
