samifox Posted March 5, 2013 Share Posted March 5, 2013 Hi All major amount of my autocad work is to offset a line inward, move the offseted line to its own layer and trim-extend the offseted line. im looking a way to autolisping it out, see the attached image 1.offset the selected poly 3 units 2.select the offseted lines 3.move them to x layer 4. if - white lines are far if - white lines are far> 3 of green lines so trim it 3 units or something... competing this willsave lots of lots of time GOD BLESS Thanks Shay Quote Link to comment Share on other sites More sharing options...
MSasu Posted March 5, 2013 Share Posted March 5, 2013 If you create polylines from the green contours, then by offsetting them, will get a contour that doesn't require additional fixings. Quote Link to comment Share on other sites More sharing options...
samifox Posted March 5, 2013 Author Share Posted March 5, 2013 hi totaly wrong ! i post that image becuase i didnt want pepole to imagin see in the image whats hapaning only with offseting the polyline and compare it to my original post Thanks Shay Quote Link to comment Share on other sites More sharing options...
tzframpton Posted March 5, 2013 Share Posted March 5, 2013 totaly wrong !No, not wrong. MSasu is 100% correct. If you use a POLYLINE instead of LINE to create the green lines first, when you offset, it'll generate the exact contour of the white polylines, and the OFFSET command already has an option to put the offsetting objects to any layer you choose. Give it a shot and see for yourself. Quote Link to comment Share on other sites More sharing options...
eldon Posted March 5, 2013 Share Posted March 5, 2013 MSasu IS right in what he says, but unfortunately is not exactly what the OP requires, although it is a good start. The OP's picture looks like wall reinforcement, which needs odd lengths for bond, where a U-bend is not practicable (or something like that). Quote Link to comment Share on other sites More sharing options...
tzframpton Posted March 5, 2013 Share Posted March 5, 2013 Ah, I understand now. It does look like rebar now that I take a second look. The posts are confusing to me.... Quote Link to comment Share on other sites More sharing options...
pBe Posted March 5, 2013 Share Posted March 5, 2013 Looks fun to write a code for that. perhaps more info from the OP. What is that extending line at the lower right corner? Quote Link to comment Share on other sites More sharing options...
eldon Posted March 5, 2013 Share Posted March 5, 2013 Probably 12 times the bar diameter or 6", whichever is the greater Quote Link to comment Share on other sites More sharing options...
pBe Posted March 5, 2013 Share Posted March 5, 2013 Probably 12 times the bar diameter or 6", whichever is the greater Maybe you're right. Your guess is as good as mine eldon Rebars is all greek to me. Quote Link to comment Share on other sites More sharing options...
Bill Tillman Posted March 5, 2013 Share Posted March 5, 2013 You can do this but it will involve some detailed and carefully organized coding. As I see it, when you offset the green polylines you will end up with what MSasu outlines. Then you could explode the offset polylines to get individual lines to work with. You would then have a lot of complex coding to do to work this out, but it could be done. If it were me, I'd try to approach it from this angle. Since you draw the polylines in the first place, you know the coordinates of the end points. Placing those coordinates into an array you could loop through them to construct the white lines as needed. Again, I'm just looking at this for the first time, but like all things with LISP, if you can draw it, you can usually program it to be drawn. As each white line is drawn you would of course be adding or subtracting the offset dimension (in this case 3) from the one or more of the coordinates of the end points. I apologize that I cannot post code to do this, but I believe it could be done like this. And, as always, there is usually more than one way of accomplishing this. My next approach would be, do the green lines need to be polylines in the first place? If not, then offsetting them and then extending and trimming them would be much easier. In the end you end up with the same view, but the green lines would be individual lines, not polylines. Quote Link to comment Share on other sites More sharing options...
samifox Posted March 5, 2013 Author Share Posted March 5, 2013 Hay people J The O key in my keyboard is all broken. 2 years ofoffseteting and extending lines for reinforcement rebars( Sorry I didt mentionit was rebars, I didn’t thing its relevant at all) Ok…so storing the coordinates in an array and construct therebars line as needed, does it mean that you ignoring the trim-extend command totally?Interesting approach. You got it out of the box. You made me think that using polar() and line command withina lisp can be a solution , right? Obviousl, my LISP skills cannot afford it now. Im sure lotsof drafters (with messy O key like me) would be happy to have that lisp. Thanks Shay Quote Link to comment Share on other sites More sharing options...
Bill Tillman Posted March 5, 2013 Share Posted March 5, 2013 Looking at it a second time, there wouldn't be the need to store the coordinates in an array, although that too would work. But since you know the coordinates of the intersections of the green lines you could easily use polar coordinates to draw the white lines. I realize this is probably over simplification. One would have to actually start building the program to do this. I use polar coordinates to draw lots of objects with LISP. My 'O' key is intact though. Quote Link to comment Share on other sites More sharing options...
samifox Posted March 5, 2013 Author Share Posted March 5, 2013 Yama...I just waiting for the right time to run away from my wife to code it Quote Link to comment Share on other sites More sharing options...
samifox Posted March 7, 2013 Author Share Posted March 7, 2013 Can I achive it by using revitstracture..? Quote Link to comment Share on other sites More sharing options...
tzframpton Posted March 7, 2013 Share Posted March 7, 2013 You don't draw in Revit like you do AutoCAD. You can host rebar in structural walls, framing, etc. Quote Link to comment Share on other sites More sharing options...
samifox Posted March 8, 2013 Author Share Posted March 8, 2013 common gurus... i hardly able to draw a simple line with lisp. for you guys is POC....it will help me a lot. again need a lisp to create rebars (as seen in my original post) Thanks Shay Quote Link to comment Share on other sites More sharing options...
eldon Posted March 8, 2013 Share Posted March 8, 2013 Have you looked at RebarCAD? It seems that you want a member of the Forum to provide you with a FREE rebar lisp. Search the web first, you may find something already there. Quote Link to comment Share on other sites More sharing options...
