KTS Posted March 9, 2013 Share Posted March 9, 2013 When using a design suite e.g autocad building suite containing various products - architecture, structual detailing, autocad, revit structure, navisworks etc, can i switch from one product to another without first closing the dwg file? E.g Start a file in autocad then sitch to autocad architecture workspace without first closing the original file and re-opening it as autocad architecture Thanks Quote Link to comment Share on other sites More sharing options...
Murph_map Posted March 9, 2013 Share Posted March 9, 2013 What you are asking for the answer is not as you want. If you have a dwg open in AutoCAD and start to edit it then start AutoCAD ARCH and open the same dwg it will open as a "read only" not allowing you to edit and save those edits. IOf you have a dwg open in any AutoCAD verticals as a dwg and try to import into Revit you may get the "File in Use" message and it will not import. Quote Link to comment Share on other sites More sharing options...
KTS Posted March 10, 2013 Author Share Posted March 10, 2013 Thanks for info Quote Link to comment Share on other sites More sharing options...
