mathieucraveiro Posted March 10, 2013 Share Posted March 10, 2013 Hello to all of you, I come to you because I need help with a project I have realized in the framework of a research project: the goal is to create automatically using a lisp, public lighting systems by indicating some data first. The user must then enter some data, such as the distance between the candelabra, the distance between the edge of the roadway and the candelabra and the offset distance between the networks ECP (lighting) and candelabra. Knowing that the networks will appear below or above the candelabra (plan view). To better understand along with this application a print screen to understand with in green the work program will lisp done. If someone has an idea, thank you very much in advance PS: sorry for my faults but i'm french thank you so much Quote Link to comment Share on other sites More sharing options...
