Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 48 of 48
  1. #41
    Forum Deity pBe's Avatar
    pBe's Computer Details
    Windows 8.1
    Landscape
    AutoCAD 2015
    Apr 2010
    3,005
    Try changing this and see what happens
    Code:
    (setq fname (strcat (getvar 'dwgprefix)  (getstring "\nEnter file name ")))
    ....(close fout)
    (startapp "Notepad"   fname)
  2. #42
    Junior Member
    AutoCAD 2010
    Mar 2013
    23
    Command: ; error: malformed string on input
  3. #43
    Windows 8.1
    Landscape
    AutoCAD 2015
    Apr 2010
    3,005
    Bigal will probably edit the code on post # 33 and will set you right.
    The generated error [ ; error: bad argument type: streamp nil] is from the lack of a valid argument supplied to this line (close fout). Now what we did is ensure the path is valid via
    (getvar 'Dwgprefix) and an additional function to open the created text file (startapp "Notepad" fname).
    The error you're getting now is from something else entirely.[syntax]
    Wait for Bigal to modify the code Drafty
  4. #44
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,702
    I ran it on your drawing and its fine Like Pbe I think the problem is in the directory name if you use a directory with a space in the name it can cause problems. Do the values appear on your screen press F2 ?
    Also I have limited time at moment it needs a bit more cleaning up it needs a seperate routine for mtext so it recognises line by line.
  5. #45
    Junior Member
    AutoCAD 2010
    Mar 2013
    23
    Thanks guys. I changed the directory to "C:Test/" and added a file extension. That then worked
    Command:
    Enter file name test1.csv
    Select objects: Specify opposite corner: 2 found
    Select objects:
    ABC\P123\PZZ
    DEF\P456\PYY
    Command:
    The finish line is in sight. Please see the screen shot attached
  6. #46
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,702
    Can some help please with a simple mtext to line by line list I am not sure that the abc\\1234\\has more info in it. I am trying to finally fix this up for drafty.
  7. #47
    Luminous Being BlackBox's Avatar
    BlackBox's Computer Details
    Windows 8.1 Professional, Server 2012 R2 Datacenter
    Dell Precision T3600
    Hex-Core Intel Xeon 3.2Ghz
    32GB
    3GB NVIDIA Quadro K4000
    2 x 240GB Samsung EVO SSD (RAID 0)
    1TB Western Digital VelociRaptor 10K RPM
    Dual 24" Dell Ultrasharp Widescreen Monitors
    Civil
    BlackBox's Discipline Details
    Senior Civil Designer
    Civil
    Public/Private Land Development, Transportation, and Utilities.
    Civil 3D 2016
    Nov 2009
    5,282
    Quote Originally Posted by BIGAL View Post
    I haven't read the entire thread, but I believe you're looking to parse the TextString Property string value by removing the myriad formatting characters (i.e., \P, etc.), where DEF\P456\YY is:
    Code:
    DEF
    456
    YY
    ... And you're after
    Code:
    (list "DEF" ;| delim char here? |; "456" "YY")
    ... Not sure if all of the various formatting characters are documented in one, single location (perhaps Lee knows? He's done a lot with this for BFIND I believe).
    Cheers
    "Potential has a shelf life." - Margaret Atwood
    AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized Developer
    Sincpac C3D ~ Exchange Apps ~ Autoloader ~ AutoCAD Security
  8. #48
    Forum Newbie
    Civil
    AutoCAD 2010
    Nov 2016
    8
    Can somebody help me make change in the code?
    I would like each coordinate to be on a separate line and empty row between each polyline.
  1. Extracting xyz coordinates from 3d polylines
    By 1ridgey in forum AutoCAD Beginners' Area
    Last Post: 13th Apr 2012, 02:08 am
  2. How to do this handle????
    By stevep80 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 3rd Jan 2012, 08:08 pm
  3. extracting cursor coordinates
    By rusty in forum AutoCAD Drawing Management & Output
    Last Post: 29th Jun 2006, 10:30 am
Tags for this Thread
