Results 1 to 9 of 9
    Senior Member
    turboCAD's Computer Details
    Windows7
    AutoCAD 2011
    Aug 2012
    București, România
    113
    Default HDD crashed, recovered ACAD files invalid.How to reconstruct invalid .DWG files?
    Hello !
    About a month ago the HDD (wd7500bpkt) of my Acer 7750G laptop decided to teach me a lesson about backing up data and not putting all the information on the same data storage device no matter how reliable the classic HDD has become.
    The hdd failed and I tried to fix it with a recovery software and damaged it even further. I took it to a data recovery firm and they managed to recover some data but most of it is non usable(I am referring to .dwg files). The following message appears when I attempt to open a damaged .dwg file:
    "Drawing file is not valid"
    However, the file amounts to 1177 KB* which, to me, means that the file contains information but with missing bits; those missing bits may be interpolated using those that are intact as I don't think the .dwg file is encrypted with random sequences that can not be predicted(*that is roughly the same size it had prior to the failure).
    I found "DWG Repair Toolbox" but have not tried it yet.
    Has anyone tried repairing a damaged .dwg file and was successful in doing so ?What was the procedure, what software has been used?
    Thank you !
    AND
    -always back up your work (memory stick + Mitsubishi-Verbatim archiving dvds)
    -don't try to fix something as important as a hdd that contains all of your work and important documents with software you have just found out about,
    as you will only worsen the situation: do not reconnect the hdd to voltage and take it to a data recovery company.
    - defragment your HDD* periodically as it greatly improves the chance of a full recovery for a given file (*defragmenting is recommended for the classical, spinning platters hdd and not for the SSDs )
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    Did you try to Recover or Audit the drawing?
    Insert into a new .dwg or XREF?
    See if there is a .bak file of the drawing and rename?
    Senior Member
    Windows7
    AutoCAD 2011
    Aug 2012
    București, România
    113
    Quote Originally Posted by SLW210 View Post
    I tried audit and it could not open it.
    Now, after I read what you told me, I changed the extension from .bak to .dwg and it worked in one out of four files so it is a good start.
    I will also try your other suggestions and post the results.
    Thank you, SLW210 !
    Senior Member
    Windows7
    AutoCAD 2011
    Aug 2012
    București, România
    113
    I tried to insert it: Insert/dwg reference/
    and this was autocad's conclusion:
    [Window Title]
    XATTACH - Invalid File
    [Main Instruction]
    This file cannot be opened.
    [Content]
    The problem can be caused by several things:
    - The data in the file is corrupted
    - The file is an earlier format that is no longer supported
    - The file format is not supported
    Try to obtain a better copy of the file, recreate the file using different settings, or convert the file to a supported file format.
    [Close]
  5. #5
    Senior Member
    Windows7
    AutoCAD 2011
    Aug 2012
    București, România
    113
    click red A in left corner/ Drawing Utilities/Recover/Recover with Xrefs
    The drawing could not be recovered
    Unable to recover drawing.
  6. #6
    Senior Member
    Windows7
    AutoCAD 2011
    Aug 2012
    București, România
    113
    this is interesting: I tried to insert another invalid file and when I selected it in the "Insert DWG reference" dialogue,
    a correct preview of it appeared in the small window at the top right of the dialogue box
    then, after clicking "Open", the "Attach external reference" dialog box also showed a correct preview of the file but after pressing ok:
    Attach Xref "tije": C:\Users\Dr. Evil\Desktop\recuperate\tije.dwg
    ** File C:\Users\Dr. Evil\Desktop\recuperate\tije.dwg isn't a valid drawing.
    The previews were correct but the file is not valid.
    The same file analyzed with "recover" yielded a partially recovered drawing: 72 errors found and fixed and 92 files erased
    but I was not allowed to save it
    AutoCAD Message
    One or more objects in this drawing cannot be saved to the specified format. The operation was not completed and no file was created.
    OK
    I selected the remaining objects and tried to copy and paste them in a new .dwg file but
    select,Ctrl+C, => "Copy to clipboard failed"
  7. #7
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    The previews are just saved image files and not the actual DWG file.
  8. #8
    Senior Member
    Windows7
    AutoCAD 2011
    Aug 2012
    București, România
    113
    I feared that.
  9. #9
    Senior Member
    Windows7
    AutoCAD 2011
    Aug 2012
    București, România
    113
    Does anyone know how to recover autocad files from "pagefile.sys " file in Windows
    or from hiberfil.sys ?
  1. Invalid URI
    By jumbo55r in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 3rd Oct 2012, 01:56 pm
  2. ATTEXT:invalid field specification, invalid field specification, etc etc
    By Edward Teller in forum AutoCAD Beginners' Area
    Last Post: 27th Mar 2012, 05:18 pm
  3. Invalid CUI
    By SanMiguel in forum CAD Management
    Last Post: 8th Apr 2011, 08:49 pm
  4. Invalid solids in ACAD 2000
    By WagglyFawn in forum AutoCAD 3D Modelling & Rendering
    Last Post: 23rd Oct 2007, 03:07 pm
  5. Need to convert (Xsteel) .nc1 files to conventional .dxf ACAD files...
    By amarinaro in forum AutoCAD Drawing Management & Output
    Last Post: 17th Jul 2007, 04:03 pm
