Results 1 to 3 of 3
    Junior Member
    not specified
    May 2006
    12
    Default accessing a point which is a block
    i have saved a point as a block and now want to access it when i run another macro.how do i do that??an example would be gr8 help
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 7 Pro x64
    Intel DZ77RE-75K
    i7-3770K 3.50GHz
    32GB
    Nvidia Quadro 2000
    125GB SSD
    500GB SATA
    ASUS 27" / ASUS 24"
    Civil
    Civil 3D 2013
    Sep 2005
    Houston
    3,633
    Access what, it's coordinates? We need a little more info as to what you are doing. Thanks.
    Junior Member
    not specified
    May 2006
    12
    Quote Originally Posted by rkmcswain
    ya access its coordinates.actually i want to insert a block at a point which itself is already saved as a block.
    may be u can tell wahats wrong in the following code--->
    there is a horizontal beam resting on 2 vertical columns.the foll. macro asks the user to scale one of the vertical columns.a selectionset exists in the drawing
    Option Explicit
    Public Sub structmod()
    Dim objent1 As AcadEntity
    Dim pickpt As Variant
    Dim pickpt1 As AcadPoint
    Dim pickpt2 As AcadPoint
    Dim newHeight As Double
    Dim objset As AcadSelectionSet
    Dim objSelections As AcadSelectionSets
    Dim objref As AcadBlockReference
    Set objSelections = ThisDrawing.SelectionSets
    Set objset = objSelections.Item("abcd")
    With ThisDrawing.Utility
    .GetEntity objent1, pickpt, vbCr & "Pick the column:"
    newHeight = .GetInteger(vbCr & "enter scale factor in Z direction selected column:")
    End With
    Set pickpt1 = ThisDrawing.Blocks.Item("firstcorner")
    Set pickpt2 = ThisDrawing.Blocks.Item("secondcorner")
    If pickpt(0) >= pickpt2(0) Then
    Set objref = ThisDrawing.ModelSpace.InsertBlock(pickpt2, "vertical2", 1#, 1#, newHeight, 0)
    Else
    Set objref = ThisDrawing.ModelSpace.InsertBlock(pickpt1, "vertical1", 1#, 1#, newHeight, 0)
    End If
    objent1.Delete
    End Sub
