Helpfull sights
welldriller
I know nothing about 3dmax - but ran across this site and thought it might be useful to some one.
Crazy3dsmax Tested this - will not work - see below
NOTE: If the above link does not work than type it in the search bar of your search engine. add the www. to crazy3dsmax.com :)
Edit:
Welldriller, you left an "s" off the url. ;)
Sean
Edited by f700es
link willnot work (edited again, f700es)
The above was for 3dmax but I also found another site that could be useful to architects but did not know where to put it
The same applies to this - if the link does not work then type in in your search engines search bar.
http://www.cad-architect.net/
if the link does not work www. cad_architect.net/http_main/cad_drawing.html
Hope this may help some one
Ok I tested it and the link will not work I think that the _ is not being put in the link ???
Edited by f700es
link does not work
Thank you Cad64 for fixing my mistakes. That is a beautiful scene. It looks as though it is something that could be found in Mexico
For those that are interested in learning lisp you might take a look at
You will have to type the following in the search bar of your search engine I can not get link to work form here.
(www.) cs.gmu.edu/~sean/lisptutorial.html click search
Then click on learning lisp fast (it should be at the top of the page.)
Also ReMark has a good list of sights in the LEARNING LISP forum
Edited by welldriller
I've moved this thread to the "Useful Links" section, since it seems to be filling up with links to sites that don't really have anything at all to do with 3ds Max.
  • 2 weeks later...
  • 4 weeks later...
