addesigns Posted March 21, 2013 Share Posted March 21, 2013 Why is it that when I adjust the bottom clip and vew depth in my enlarged stair plan it does not cut out the lower portion. I have the top plan and cut plan correct and it cuts off where it should, but when I adjust either the bottom plan or view depth or vice versa to show just a litle below, it does not cut the stairs off. Its shows the whole thing and I dont want it to show all the stairs below. I have no underlay showing. I just cant figure out why it wont cut. Also, what is the point of view depth if that is what the botom plane is? Quote Link to comment Share on other sites More sharing options...
tzframpton Posted March 21, 2013 Share Posted March 21, 2013 I don't use Detail Views for things like enlarged plans. I duplicate the View, categorize it, use the Detail View tool but I reference the View instead, to keep the associativity with the callout bubble. Using the View Range on a Plan View behaves much better than using an actual Detail View. There are problems and limitations to a Detail View because the slicing plane make things look much differently than a normal Plan View. Furthermore, I use Plan Regions around stairs a lot to isolate an area where I need a View Range to effect just the stairs differently than the rest of the View. Primarily to control the stair cut symbol. Hope this helps. Quote Link to comment Share on other sites More sharing options...
