Results 1 to 4 of 4
Thread: Z values
    Forum Newbie
    not specified
    Jul 2006
    Australia
    7
    Default Z values
    G’ Day all
    I have come across a problem in Auto CAD which I hope someone on this site will be able to help me with??
    I am using AC 2004 and am working on a new project which is a big site layout so I am at times working a long way from 0,0,0. I am also working in world coordinates and using Xrefs to split up site locations. BUT when I am sometimes drawing I get Z values in the drawing and I have only been drawing in 2D .
    It seems to happen when you cut and paste from different parts of the site drawing??
    And offcourse when Z values start to arrive they spread like wild fire.
    Does anyone have any ideas how to stop this and keep clean 2D drawings or is there a problem with AutoCAD when working in world coordinates and so far from 0,0,0?
    Kind Regards
    Trev
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    8GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    In a nutshell, I create 3D models from the client's CAD files or design sketches, which I then use to produce high quality rendered images. Click on the link in my signature to view my portfolio. I'm always looking for work, so let me know if you need any renders. :)
    3ds Max 2011
    Feb 2006
    Southern California
    8,433
    I have a ritual that I go through whenever I receive a file from an outside source. I first save out a copy of their file to an xref folder and place an 'X' in front of the name so that I know it's an xref. That way, I always have their original to go back to if need be. I then go through the xref drawing and detach all xrefs and image files, (I don't like nested xrefs). I delete all layer filters, layer states, layout tabs and any excess junk around the perimeter of the project limits. I then purge, audit and flatten. This makes the file as lean and clean as possible. Only then do I insert into my drawing. Ever since I adopted this policy, I never have problems with Z values anymore.
    "Work Smart, Not Hard"
    Click to View My Portfolio ( Updated 05/21/2013 ) --->
    http://www.rdeweese.com/
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,074
    If a drawing has z values and you copy and paste using osnaps, then you will get the z value proliferation problem you describe. I don't believe distance from 0,0 has anything to do with it.
    You can use the Express Tools command "flatten" to set all z values to 0 (in most cases).
    Forum Newbie
    not specified
    Jul 2006
    Australia
    7
    I will give that a go from now on. But the system I am working on is full of Z values.
    Fllatten is good but its not working very well. Thanks for your help.
    I will try some things on monday and keep you posted.
