Re-appearing Workplanes
dgameman
So I have never seen this before and it is now doing this in all of my new assemblies. I have multiple parts that have been placed in a general assembly. Some are parts derived from a single solid, others are parts that were started as a standard part. When I turn off the visibility of any of these parts they dissappear like normal. When I turn the visibility back on they become visible along with every work plane that is in the part. It does this everytime I turn the visibility on and off and on both solid parts and regular parts. Also when I go back into older sketches of those parts all the work planes turn on again and cannot be turned off while I am in the sketch. This almost sounds like a software problem but I am not sure and I am tired of turning off the workplanes over and over again. Does anyone have any ideas why this may be happening?
Thanks for the help.
I know that I can turn off all workplanes with Alt+], but when I create a new workplane it is by default already turned off and when I go to tuirn it on it brings me back to the original problem, so this works when trying to get all of them off but not a working fix.
Edited by dgameman
  • 2 weeks later...
Perhaps try using a view rep to save your workplane visibility states. The part workplane visibility is managed in the part. So if you have all the workplanes turned on in the part but hide them in the assembly, once it regenerates the workplanes will come back. I'm not sure however why this is a new problem unless a template got messed up or a view rep is locked. I'm just spit-balling a bit here.
  • 4 weeks later...
