RedRex Posted April 1, 2013 Share Posted April 1, 2013 Getting the proper text size in model space is driving me a little crazy. If single or multi-line text is set at a particular size, notes or dimension text for one object (like a fabrication detail) could be legible, where as text for a much larger object (like a floor plan) could be hard to read. Is there a way to compensate for this? Or is it a matter of manually adjusting text size for every drawing component? So far, I have found the easiest way is through the Quick Properties feature. Cheers -Rex Quote Link to comment Share on other sites More sharing options...
mikekmx Posted April 1, 2013 Share Posted April 1, 2013 i prefer to annotate in paper space, after i have finished drawing and have set up viewports. That way text, arrows etc are the same size. sometimes i will swap stuff over with changespace Quote Link to comment Share on other sites More sharing options...
RobDraw Posted April 1, 2013 Share Posted April 1, 2013 Two more solutions: 1. Set up text styles for the different scales. 2. Annotative text. Quote Link to comment Share on other sites More sharing options...
RedRex Posted April 2, 2013 Author Share Posted April 2, 2013 Two more solutions: 1. Set up text styles for the different scales. 2. Annotative text. I've heard of annotative text, but not really sure what it is. I'll have to look into it. Thanks Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 2, 2013 Share Posted April 2, 2013 Properly done annotative text will have one or more scales assigned to it that correspond to the scales assigned to the paper space layout viewports one expects the text to be displayed in. Thus, when printed all the text will be a uniform height despite the fact it may appear in different viewports that utilize different scales. Quote Link to comment Share on other sites More sharing options...
