MisterJingles Posted April 3, 2013 Share Posted April 3, 2013 Hi all I'm wondering if there is a script (I dare not say LISP as I have never used LISP routines) which can simplify my life a little. Our company manufacture and sell modular buildings, our walls are made primarily of 42mm thick 1179mm long panels. So when drawing the plan view of our buildings in MS we simply offset 1 line from another by 42 units and this represents our wall thickness. These buildings can be very large and can comprise of hundreds and hundreds of panels. The sales guys are often asking me for a measurement of all the walls making up a building so that they know how many panels to cost for. Currently I sit in MS and measure each length of wall individually which takes a fair amount of time. Is there a script I could run instead which calculates the total length of line segments on my WALL layer which I can then divide in half to get an approximate total wall length? Sorry for the long-winded question, any ideas? Thanks Rob Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 3, 2013 Share Posted April 3, 2013 The drawings have dimensions on them don't they? Quote Link to comment Share on other sites More sharing options...
MisterJingles Posted April 3, 2013 Author Share Posted April 3, 2013 The drawings have dimensions on them don't they? Of course, but like I said they can be really large buildings such as the one pictured below. As you can see this can take up some time measuring manually. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 3, 2013 Share Posted April 3, 2013 Doesn't AutoCAD Mechanical have Bill of Materials capabilities? Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 3, 2013 Share Posted April 3, 2013 Aren't there lisp routines that can add dimensions? Quote Link to comment Share on other sites More sharing options...
MisterJingles Posted April 3, 2013 Author Share Posted April 3, 2013 (edited) Doesn't AutoCAD Mechanical have Bill of Materials capabilities? It does, I haven't used it before. At first glance it seems complicated but if its what I'm looking for I could spend some time familiarizing myself with it. I realise I could also do an Extraction and extract the lines and calculate from there but again this is long-winded. Am I missing something? Is a script, or possibly a LISP routine, not an option here? Edited April 3, 2013 by MisterJingles Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 3, 2013 Share Posted April 3, 2013 Re: lisp routines. Read this all the way through (it's not that long). http://www.cadtutor.net/forum/showthread.php?71186-Add-%28sum-up%29-All-dimensions-in-drawing Quote Link to comment Share on other sites More sharing options...
MisterJingles Posted April 3, 2013 Author Share Posted April 3, 2013 Re: lisp routines. Read this all the way through (it's not that long). http://www.cadtutor.net/forum/showthread.php?71186-Add-%28sum-up%29-All-dimensions-in-drawing Thanks ReMark, we are getting closer to what I'm after. The only hassle Ill have with that LISP is that I do not dimension every single panel on a layout, and also one dimension will often represent multiple walls so would not give me an accurate calculation. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 3, 2013 Share Posted April 3, 2013 I did the best I could. The rest is up to you. Quote Link to comment Share on other sites More sharing options...
rkent Posted April 3, 2013 Share Posted April 3, 2013 First isolate the wall layer then look into a lisp program like http://www.jtbworld.com/lisp/bomlengths.htm Finally divide by 2. Quote Link to comment Share on other sites More sharing options...
MisterJingles Posted April 4, 2013 Author Share Posted April 4, 2013 Thanks rkent this is exactly what I am after. Works a charm! Thanks for your help. Quote Link to comment Share on other sites More sharing options...
