Results 1 to 3 of 3
    Forum Newbie
    AutoCAD 2012
    Apr 2013
    2
    Default Can you export cross section lines from hec ras to autocad??
    I need the actual cross section LINES that are shown in the HECRAS model, not just the alignment... I've tried check marking everything that the "GIS export" option in HECRAS gives you to no avail (all I can get into ACAD is the alignment, not the 74 cross section lines along with it)... HELP!!!!
    Senior Member
    jammie's Computer Details
    W7
    Civil
    jammie's Discipline Details
    Project Technician
    Civil
    AutoCAD 2016
    May 2006
    Ireland
    316
    It depends on how the data was imported into HEC-RAS. If the source data was imported as a geo file then you'll be able to export it out as a geo file again from HEC-RAS. Refer to the HEC-RAS manual for details. I generally like to check the exported data before trying to bring it into ACAD.
    Open the exported geo file in a text editor such as notepad++. Refer to the section in the file that has the stations. Among other things the stations in the exported file will contain vertex data, see if the information looks correct to your co-ordinate sysytem.
    Forum Newbie
    AutoCAD 2012
    Apr 2013
    2
    Thanks for the help... ANOTHER problem I am currently having is exporting just the alignment. It worked before, but now it's not exporting the alignments. I've created the alignments, but the file created is empty after the export...?
  1. autocad cross section and long section
    By haseebsarwar42 in forum Civil 3D & LDD
    Last Post: 1st Sep 2012, 09:55 am
  2. Cross section in autocad
    By scythia123 in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Jul 2012, 12:40 pm
  3. 3d cross section?
    By Seth385 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 16th Jan 2012, 10:01 pm
  4. Cross-section, elevation and detail cross reference labels
    By tinKing in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 6th Apr 2011, 03:50 am
  5. export cross section data?
    By javent in forum Civil 3D & LDD
    Last Post: 11th Jun 2010, 03:42 am
Tags for this Thread
