Having trouble turning mesh into solid
octo12
I have imported data showing the contours of a surface into autocad.. I want to output it as an .stl of the same contour map but with a higher resolution and smoothed out. I created a mesh and exploded, but now at the stage where I want to convert to solid it doesn't let me do it..
Is there a way of making the mesh into a solid?
Command: _convtosolid Mesh conversion set to: Smooth and optimized.
Select objects: Specify opposite corner: 53646 found
Select objects: Specify opposite corner: 37336 found (6124 duplicate), 84858
total
Select objects:
84858 objects cannot be converted.
Command:
Command:
Command: _EXPORT
Select solids or watertight meshes: Specify opposite corner: 84858 found
Selected objects must be solids or watertight meshes.
84858 objects removed from the selection set.
Your best bet would be to supply a copy of your drawing. You may have to utilize Dropbox as I'm guessing the file size will be over the limit allowed here.
Ye its 35mb.. :( I will have a look at dropbox and zippyshare etc. I have uploaded it to google drive to show a friend.. Is there a way of sharing that publicly on this forum without uploading again?
I have imported data...
What format was the imported data?
Is that a picture of the original or after you tried to "fix" it?
Yes thats after I "fixed" it ;-) there was no mesh before.. I can also upload the original before any possibly counterproductive tinkering
