provas_ce Posted April 7, 2013 Share Posted April 7, 2013 Hi there, I Posted This problem twice but it doesn't showed in the forum. I don't know why, whatever, My problem is making Array with a circle and a line[same as to radius]. When i use array between them to create 9 more lines, some lines are becomes bigger then the original line. why this happen? I attach a file to be understand clearly. Zoom the intersection point of lines and the circle. Any suggestion will be appreciate . Thanks in advance, Provas. Quote Link to comment Share on other sites More sharing options...
provas_ce Posted April 7, 2013 Author Share Posted April 7, 2013 Oppz, I forget to attach the file. Here it is. problem.dwg Quote Link to comment Share on other sites More sharing options...
eldon Posted April 7, 2013 Share Posted April 7, 2013 If you check the length of each line in the Properties, you will see that they are all 8" exactly. The apparent projection of a line beyond the circle is all to do with how the circle is drawn on the screen at differing magnifications. After you zoom in, do a regen and all the lines will finish at the circle. Quote Link to comment Share on other sites More sharing options...
provas_ce Posted April 7, 2013 Author Share Posted April 7, 2013 Yeah you're right thanks eldon, thanks to clear my confusion ... Quote Link to comment Share on other sites More sharing options...
