Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Forum Newbie
    AutoCAD LT 2006
    Apr 2013
    8
    Default Model space in wrong scale!
    I have a drawing with the model space set at 3/16" scale. I've never worked like this before (I obviously always scale in layout space). However, I need to get this drawing back to normal scale so I can work on it.
    I have no idea how to use the scale factor on this to get model space from 3/16" to 1:1.
    Please help. I'm getting really frustrated.
    Thank you!!!
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,852
    To get everything back to full size scale your drawing by a factor of 64.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,084
    Or just scale with the reference option for known distances.
    Forum Newbie
    AutoCAD LT 2006
    Apr 2013
    8
    Thank you. I had tried that, only it made the drawing so large that I couldn't even navigate it. I wonder if I'm incorrect about the scaling? It's the weirdest thing I've come across. Sometimes exterior double doors are measuring 6'-0", sometimes they're measuring over 300'-0". I cannot figure this out. I ended up playing around with it and scaled it up 1.325. I have no idea why that might have worked. It's close. Not exact, but close.
    I appreciate your assistance! I was frazzled. Still perplexed...but things are currently working.
  5. #5
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Scaling is HS mathematics.
    Measure current size of something you know the true size should be.
    SF*measured size=true size
    therefore
    SF=true size/measured size
    Double check.
    If working in feet and inches be sure to account for units.
    This is probably the most common question that appears here, yet should be understood by anyone entering this field.
    Sometimes ....measuring 6'-0", sometimes ....measuring over 300'-0". I cannot figure this out.
    Neither can I. Attach your file here.
    If you can't figure it out - attach your file here.
  6. #6
    Forum Newbie
    AutoCAD LT 2006
    Apr 2013
    8
    I know - it's such a simple formula, and yet I just couldn't figure out what that equation was! I still can't figure out how the architect did this drawing. I think it's working now, but I'm still getting some odd dimensions. The file is so large, I don't think I can attach it or I would.
    I appreciate the guidance and support. If I can figure out how to reduce the size of the file, I will (and, of course, if you know how I can do that, tell me please!).
    Thanks again.
  7. #7
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Quote Originally Posted by intangerine View Post
    ... I still can't figure out how the architect did this drawing....
    Say no more.
    You could delete all but a couple of areas of geometry. That should reduce the file size. Make sure you have a back-up and do a File>Save As (save as reduces file size)
    I am interested in the areas of great discrepency that you mention.
  8. #8
    Forum Newbie
    AutoCAD LT 2006
    Apr 2013
    8
    I keep trying to delete a lot of the file and resend, but it's still too big. Maybe they really messed this file up!?
    Sometimes when I measure, though previously it measured correctly, it will start to dimension weird (like a vanity that should be about 24" wide will all-of-a-sudden measure out at 20'-0"). This is the strangest file I've worked on.
    I'm very, very curious to see if you find what I'm finding! And, if you find why this is occurring. I'll keep trying to delete and see if I can save and resend.
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,852
    Erase 90% of the drawing then save it under a new name. Attach the drawing file to your next post.
    I gave you the scale factor based upon the information you provide that the drawing was done at a 3/16"=1'-0" scale. Did you at least try rescaling the drawing or not?
    What makes you think the drawing was done "to scale" as though drawn on a drafting board?
    Was a layout and viewport used in this drawing?
  10. #10
    Super Member
    AutoCAD 2012
    Jun 2012
    902
    It will certainly be interesting to see how this one turns out. In the old days, before viewports, you could certainly find views with differing scales. Scaling everything up would not necessarily fix the prob in that case. But you should get consistent results from the same view, unless you have more than one dimension style you are using and checking it that way. BTW, it was not clear to me from your description if you are using dimensions to check the drawing, or if you are using the Distance command. The latter would be more definitive, as Dimension styles can be set up to show measurements altered by scale factors. Regarding model space: the Model tab is the place to be. I don't think it can be renamed; but you can rename a layout tab, e.g., ModelSpace.
    When all you have is a hammer, everything looks like a nail.--
    “Doc, it hurts when I do this.” “Well, don’t do that!”
    “Well, if you don’t know, I’m certainly not going to tell you!”
  1. Linetype scale from Model space to Paper Space
    By sam_dubya in forum AutoCAD Beginners' Area
    Last Post: 6th Feb 2012, 04:26 am
  2. Help getting the right scale from Model Space to Paper Space
    By Susan-Skye in forum AutoCAD Drawing Management & Output
    Last Post: 28th Oct 2010, 01:51 pm
  3. Paper Space Scale question: What have I done wrong?
    By Mauser in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 3rd Jun 2010, 10:55 am
  4. Scale the lintype in model space & paper space.
    By yadavdinesh2008 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 27th May 2009, 06:14 pm
  5. linetype scale in Model Space/Paper Space
    By delangorgon in forum AutoCAD General
    Last Post: 2nd Oct 2007, 04:55 pm
