martyy Posted April 9, 2013 Share Posted April 9, 2013 Hi I have been sent a dwg and I am trying to shrink a group of items collectively. I cannot find a way to reduce the size of it I have tried scale but I don't want to work out the scale for each group, I tried stretch but its not a single item... I am trying to reduce the width of the objects from 140mm to 110mm whilst retaining the ratio between all objects. Cheers Martyn Quote Link to comment Share on other sites More sharing options...
jammie Posted April 9, 2013 Share Posted April 9, 2013 Hi martyy, Have you tried the reference feature when using the scale command? Its a commandline option when you start scale. AutoCAD will calculate the scale factor for you - you just need to measure the original distance and the new distance as per the prompts. AutoCAD will scale the objects accordingly. Creating a block could be another option and scaling that down but that would probably take longer Quote Link to comment Share on other sites More sharing options...
martyy Posted April 9, 2013 Author Share Posted April 9, 2013 Cheers Jammie, That almost worked, but, and I failed to explain correctly, I need to retain the Vertical measurements and shrink the Horizontal only. Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted April 9, 2013 Share Posted April 9, 2013 You may be able to use a block. Define your items as a single block, scale it as needed in the X and Y dimensions, and explode it. QED. Quote Link to comment Share on other sites More sharing options...
martyy Posted April 9, 2013 Author Share Posted April 9, 2013 I was going to set it as a block but I still need individual access to all objects... Quote Link to comment Share on other sites More sharing options...
irneb Posted April 10, 2013 Share Posted April 10, 2013 ... but I still need individual access to all objects...That's why... and explode it. QED. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted April 10, 2013 Share Posted April 10, 2013 Stretch does work on multiple objects. Can you post screen shots of what you are trying to accomplish? Quote Link to comment Share on other sites More sharing options...
