Results 1 to 8 of 8
    Forum Newbie
    AutoCAD 2013
    Apr 2013
    7
    Default 3D kerb stone modelling AutoCAD 2013
    Hi,
    I have been trying to model a kerb stone in 3D. For the straight section I have no issues at all. But for the curved section I just cant get the edge detail into my model. I have attached a picture of my models. I did my curved design by drawing a circle with the desired raduis and offset the circle by required distance. Then after trimming and joining I used PRESSPULL to lift it. If anyone could provide assistance it would be very helpful. For the straight section I can draw the front face and just pull it by PRESSPULL, but I cant seem to do it with the cuvred section. Is there a way to draw the face and use PRESSPULL and pull it at an desired angle or radius?
    If anyone could provide some information it would be helpful.
    Thanks,
    M.I
    Senior Member Rewind23's Avatar
    Rewind23's Computer Details
    Windows 7 Ultimate 64bit
    ASROCK N68-S
    AMD Athlon X2 64 Dual Core 2.6GHz
    Kingston 4GB DDR2
    Innod3D 512mb nVIDIA GeForce 8500 GT
    Seagate 160gb
    Samsung 19" LCD SyncMaster 920nw
    AutoCAD 2011
    May 2011
    Philippines
    142
    @complete - i guess a CHAMFER command will help you to achieve that detail. Is this the one what you we're trying to achieve?If so, refer to the picture, what I did is I create first the profile for extrusion.(though press/pull will also work)then I extrude it then I apply the Chamfer command, I apply the chamfer to the edge highlighted with red on the left.Apply the Distance of Chamfer this refers to Distance1 & 2 just play with it to see how it works.Also, Welcome to CADTutor Forum.regards
    Forum Newbie
    AutoCAD 2013
    Apr 2013
    7
    Laughing
    Quote Originally Posted by Rewind23 View Post
    Worked like a treat. Thx alot.
    ASROCK N68-S
    Kingston 4GB DDR2
    Seagate 160gb
    AutoCAD 2011
    May 2011
    Philippines
    142
    Quote Originally Posted by complete View Post
    You're welcome.
  5. #5
    Forum Newbie
    AutoCAD 2013
    Apr 2013
    7
    Actually I have another query,
    How did you draw that curved solid? I had to draw mine by getting 2 cricles, trimming them and then using 'presspull' to lift it. If that how you did yours?
    Thanks.
  6. #6
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Your original attempt shows parallel sides.
    Rewind shows angled (pie shape) sides.
    If the Rewind's solution is what you are after you could draw the end profile and Revolve the desired angle.
  7. #7
    Forum Newbie
    AutoCAD 2013
    Apr 2013
    7
    Quote Originally Posted by JD Mather View Post
    If I were to draw it parallel sides curved, would it be same Revolve function or something different?
    Thx
  8. #8
    ASROCK N68-S
    Kingston 4GB DDR2
    Seagate 160gb
    AutoCAD 2011
    May 2011
    Philippines
    142
    Thanks.
    I created that using Circle + Offset + Line to close the profile + Trim then Extrude .JD's suggestion is definitely correct, you can simply draw the end profile and apply the REVOLVE command with defined angle of revolution.You can play in any solution that you think is easy & comfortable for you. Sometimes it just depend on what is needed to execute the modeling. And practice help you a lot into modeling. Hope it helps.
  1. Graphic card update for Inventor 2013 and AutoCAD 2013
    By Alexger in forum Autodesk Inventor
    Last Post: 27th Sep 2012, 12:01 am
  2. Problem with second monitor -AutoCAD 2013 and Inventor 2013
    By Alexger in forum AutoCAD 3D Modelling & Rendering
    Last Post: 26th Sep 2012, 02:41 pm
  3. Updated Service Pack for AutoCAD 2013 and AutoCAD LT 2013
    By AutoCAD Insider in forum AutoCAD RSS Feeds
    Last Post: 11th Sep 2012, 07:30 pm
  4. Replies: 0
    Last Post: 21st Aug 2012, 08:40 pm
  5. Kerb Design
    By Craig F in forum Civil 3D & LDD
    Last Post: 31st Oct 2010, 07:37 am
Tags for this Thread
