Results 1 to 5 of 5
    Forum Newbie
    AutoCAD 2010
    Apr 2013
    2
    Default Draw Rectangle Dimension
    Hello! I was wondering how I would go about writing a function that would calculate the length of a diagonal of a rectangle using SQRT function? I've been trying but so far nothing!
    Thanks!
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    Can you post the code you wrote so far?
    Presuming that you know the length, respectively width of the rectangle, you should use Pythagoras formula:
    Code:
    (setq sizeDiagonal (sqrt (+ (expt sizeLength 2.0) (expt sizeWidth 2.0))))
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
    Forum Newbie
    AutoCAD 2010
    Apr 2013
    2
    Thanks! I had a few simple lines, but I erased those as yours was basically what I needed. Would it be possible to write a function that would find the length & width itself? This one is out of curiosity.
    Full Member
    fabriciorby's Computer Details
    Windows 7 64 bits
    See details...
    fabriciorby's Discipline Details
    See details below.
    Telecom
    AutoCAD 2011
    Mar 2013
    Brazil
    92
    Quote Originally Posted by nejadarea View Post
    Try this:
    Code:
    (defun LM:MAssoc ( key lst / item )
        (if (setq item (assoc key lst))
            (cons (cdr item) (LM:MAssoc key (cdr (member item lst))))
    (defun c:getdist (/ s pt1 pt2 pt3 pt4 x y ent lst)
    (setq s (ssget "_+.:E:S" '((0 . "LWPOLYLINE"))))
    (if (= s nil)
    	(alert "Select a rectangle.")
    	(setq ent  (entget(ssname s 0)))
        (setq lst (LM:MAssoc 10 ent))
    	(setq pt1 (nth 0 lst))
    	(setq pt2 (nth 1 lst))
    	(setq pt3 (nth 2 lst))
    	(setq pt4 (nth 3 lst))
    	(setq x(distance pt1 pt2))
    	(setq y(distance pt1 pt4))
    	(princ (strcat "\nHeight: " (rtos y) "\nWidth: " (rtos x)))
    Yes, thanks to Lee Mac haha
    Edit: But there is some problem with this code, if you rotate your rectangle by 90º the height will become width and vice versa.
    Nothing that a if can't solve hehe
  5. #5
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,418
    Here is another method:
    Code:
    (defun c:test ( / lst sel )
        (if (setq sel (ssget "_+.:E:S" '((0 . "LWPOLYLINE"))))
                (setq lst
                    (mapcar 'cdr
                        (vl-remove-if-not '(lambda ( x ) (= 10 (car x)))
                            (entget (ssname sel 0))
                (apply 'mapcar
                    (cons '-
                        (mapcar
                            '(lambda ( x ) (apply 'mapcar (cons x lst)))
                            '(max min)
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  1. Draw a rectangle on a Block
    By rodrigo_sjc_sp in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Apr 2013, 02:38 pm
  2. Draw rectangle on polyline's vertex
    By Rakumbada in forum AutoLISP, Visual LISP & DCL
    Last Post: 31st Jul 2011, 11:35 pm
  3. How to accurately draw a rectangle ?
    By JamFam in forum AutoCAD Beginners' Area
    Last Post: 11th Apr 2006, 07:47 pm
  4. Draw Rectangle by Area
    By Brunello19 in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Nov 2005, 04:50 am
  5. Draw a rectangle in 2000 or AC LT97
    By hindsight in forum AutoCAD Beginners' Area
    Last Post: 3rd Mar 2004, 04:09 pm
Tags for this Thread
