Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
    Junior Member
    mjavy7's Computer Details
    Win7 Pro 64-bit
    Lenovo Think Pad
    Lenovo
    i7 4710MQ @ 2.5GHz
    16.00GB
    stock
    500 GB
    10T
    22's
    Construction
    mjavy7's Discipline Details
    Concrete Formwork Designer
    Construction
    Civil, Structural, Commercial, Residential, Multi-Family, High Rise, Condominiums, Energy, Industrial
    AutoCAD 2016
    Dec 2007
    Riverview, Florida
    24
    Default Print Tabs Names (or export)
    Hello All.
    I need help with AutoCAD 2013
    I have multiple drawings with 100's of tabs inside, I would like to either export or print out all of the tab names.
    If anyone knows a way to do this, I would love to hear about it.
    Thank you in advanced,
    Javier
    Luminous Being BlackBox's Avatar
    BlackBox's Computer Details
    Windows 8.1 Professional, Server 2012 R2 Datacenter
    Dell Precision T3600
    Hex-Core Intel Xeon 3.2Ghz
    32GB
    3GB NVIDIA Quadro K4000
    2 x 240GB Samsung EVO SSD (RAID 0)
    1TB Western Digital VelociRaptor 10K RPM
    Dual 24" Dell Ultrasharp Widescreen Monitors
    Civil
    BlackBox's Discipline Details
    Senior Civil Designer
    Civil
    Public/Private Land Development, Transportation, and Utilities.
    Civil 3D 2016
    Nov 2009
    5,282
    Here's a simple example for the active document:
    Code:
    (defun c:Tabs ()
      (prompt "\nTab Names: ")
      (foreach layout (layoutlist)
        (print layout)
    "Potential has a shelf life." - Margaret Atwood
    AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized Developer
    Sincpac C3D ~ Exchange Apps ~ Autoloader ~ AutoCAD Security
    Junior Member
    Win7 Pro 64-bit
    Lenovo Think Pad
    Lenovo
    i7 4710MQ @ 2.5GHz
    16.00GB
    stock
    500 GB
    10T
    22's
    Construction
    Construction
    AutoCAD 2016
    Dec 2007
    Riverview, Florida
    24
    now how do I use this? LOL
    Sorry man, this is a bit over my head.
    If you could please explain how to use this code, I would highly appreciate it.
    If there is already a place in here were it is explained let me know and I will go there to learn.
    32GB
    Civil
    Civil
    Civil 3D 2016
    Nov 2009
    5,282
    No worries; we all start somewhere.
    First, to use LISP code posted on forums, simply copy + paste the code into an empty text file, and save with a .LSP file extension. See this tutorial for loading LISP routines.
    After posting that quick sample above, I re-read your post, and saw that you said you're needing to process multiple drawings, so I thought I'd provide a 'Batch Report' routine... Once you've created the LISP file, and loaded the code into your drawing, simply invoke by entering BFINDTABS EXPORTLAYOUT Command.
    [Edit :: 2013-04-19]
    Modified code to allow for Active (current drawing), or Browse (single/multiple drawing) selection.
    I have added a DOSLIB dependency specifically to gain access to multiple file selection offered by DOS_GETFILEM function. Please download DOSLIB here, and use ARXLOAD to load your version's ARX file.
    This modification also provides a LISP callable function BBOX:ExportLayout.
    Multiple miscellaneous items corrected as well, such as non-localized variable, and non-essential code included by mistake when pulling from another routine.
    Additional handling needed for open / read-only Documents.
    Code:
    (vl-load-com)
    (defun BBOX:ExportLayout (dwgs / *error* BBOX:GetDate BBOX:GetTime
                                   BBOX:WriteData acApp oDocuments oShell path
                                   filePath dbxDoc file openDoc oLayouts layoutName
      (defun *error* (msg)
        (if file
          (close file)
        (if oShell
          (vlax-release-object oShell)
        (if dbxDoc
          (vlax-release-object dbxDoc)
        (cond ((not msg))                                                   ; Normal exit
              ((member msg '("Function cancelled" "quit / exit abort")))    ; <esc> or (quit)
              ((princ (strcat "\n** Error: " msg " ** ")))                  ; Fatal error, display it
      (defun BBOX:GetDate (date)
        (setq date (mapcar '(lambda (x) (itoa x)) date))
        (strcat (nth 0 date) "-" (nth 1 date) "-" (nth 3 date))
      (defun BBOX:GetTime (date / hr mn)
        (setq hr (nth 4 date))
        (setq mn (itoa (nth 5 date)))
        (if (= 1 (strlen mn))
          (setq mn (strcat "0" mn))
        (cond ((> 12 hr) (strcat (itoa hr) ":" mn " AM"))
              ((strcat (itoa (- hr 12)) ":" mn " PM"))
      (defun BBOX:WriteData (path dwg layoutName file / filePath date)
        (write-line
          (vl-string-right-trim
            (apply
              'strcat
              (mapcar
                '(lambda (x) (strcat x ","))
                (list (setq filePath (strcat path dwg))
                      (if (setq date (vl-file-systime filePath))
                        (BBOX:GetDate date)
                        "{ Read-Only }"
                      (if date
                        (BBOX:GetTime date)
                        "{ Read-Only }"
                      layoutName
          file
      (if (and (setq acApp (vlax-get-acad-object))
               (setq oDocuments (vla-get-documents acApp))
               (setq oShell (vla-getinterfaceobject
                              acApp
                              "Shell.Application"
               (setq path (car dwgs))
               (setq filePath
                      (strcat
                        (vl-filename-directory
                          (vl-filename-mktemp)
                        "\\Export Layout Report_"
                        (menucmd
                          "M=$(edtime,$(getvar,date),YYYY-MO-DD)"
                        ".csv"
               (princ "\nWorking, please wait...")
               (setq dbxDoc (vla-getinterfaceobject
                              acApp
                              (strcat "ObjectDBX.AxDbDocument."
                                      (substr (getvar 'acadver) 1 2)
          (setq file (open filePath "w"))
          (write-line "Directory Searched:" file)
          (write-line path file)
          (write-line "" file)
          (write-line "Drawing:,Date:,Time:,Layout Name:" file)
          (foreach dwg (cdr dwgs)
            (if (not (vl-catch-all-error-p
                       (setq openDoc (vl-catch-all-apply
                                       'vla-item
                                       (list oDocuments dwg)
              (setq oLayouts (vla-get-layouts openDoc))
                (vl-catch-all-apply
                  'vla-open
                  (list dbxDoc (strcat path dwg))
                (setq oLayouts (vla-get-layouts dbxDoc))
            (vlax-for oLayout oLayouts
              (if (/= "Model" (setq layoutName (vla-get-name oLayout)))
                (BBOX:WriteData path dwg layoutName file)
          (princ "Done.")
          (setq file (close file))
          (vlax-invoke oShell 'open filePath)
          (*error* nil)
        (cond
          (filePath
           (*error*
             "Unable to create \"ObjectDBX.AxDbDocument\" Object"
          (acApp
           (*error* "Unable to create \"Shell.Application\" Object")
    (defun c:ExportLayout (/ opt dwgs)
      (initget "Active Browse")
      (if
        (not
          (setq opt
                 (getkword
                   "\nWhat drawing would you like to process [Active/Browse]<Active>: "
         (setq opt "Active")
      (cond ((= "Active" opt)
             (if (= 1 (getvar 'dwgtitled))
               (BBOX:ExportLayout
                 (list (getvar 'dwgprefix) (getvar 'dwgname))
               (prompt "\n** Drawing not saved ** ")
            ((= "Browse" opt)
             (if (setq dwgs
                        (dos_getfilem
                          "Select Drawings"
                          (getvar 'dwgprefix)                               ;<-- default path here
                          "Drawing files (*.dwg)|*.dwg"
               (BBOX:ExportLayout dwgs)
    Inspired by a favorite routine of mine, BFIND, from Lee.
  5. #5
    Junior Member
    Win7 Pro 64-bit
    Lenovo Think Pad
    Lenovo
    i7 4710MQ @ 2.5GHz
    16.00GB
    stock
    500 GB
    10T
    22's
    Construction
    Construction
    AutoCAD 2016
    Dec 2007
    Riverview, Florida
    24
    You are the man!!
    They both work great but I must say the second one is very impressive!!!
    This is exactly what I need!!!
  6. #6
    32GB
    Civil
    Civil
    Civil 3D 2016
    Nov 2009
    5,282
    That is kind of you to say; I'm happy to help ... I've had a lot of help along the way.
  7. #7
    Junior Member
    Win7 Pro 64-bit
    Lenovo Think Pad
    Lenovo
    i7 4710MQ @ 2.5GHz
    16.00GB
    stock
    500 GB
    10T
    22's
    Construction
    Construction
    AutoCAD 2016
    Dec 2007
    Riverview, Florida
    24
    Quote Originally Posted by BlackBox View Post
    Code:
    (defun c:Tabs ()
        (print layout)
    How hard is to make this code export the list to excel like the second code?
  8. #8
    32GB
    Civil
    Civil
    Civil 3D 2016
    Nov 2009
    5,282
    Quote Originally Posted by mjavy7 View Post
    You mean, where it only prompts for a single drawing, rather than a directory of?
    Or do you mean no prompt at all; as in it only works on the drawing open when invoked?
  9. #9
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,139
    A very simplified version
    Code:
    (defun c:Tabs ()
    (setq fname "C:\acadtemp\mytabs")
    (setq fo (open fname "w"))
        (print layout)
    (write-line layout fo)
    (close fo)
    ;just open file mytabs in excel
  10. #10
    Junior Member
    Win7 Pro 64-bit
    Lenovo Think Pad
    Lenovo
    i7 4710MQ @ 2.5GHz
    16.00GB
    stock
    500 GB
    10T
    22's
    Construction
    Construction
    AutoCAD 2016
    Dec 2007
    Riverview, Florida
    24
    Either way it works for me, what ever is easier for you. I can work with either.
  1. Replies: 21
    Last Post: 14th Jul 2014, 07:04 am
  2. Replies: 7
    Last Post: 28th May 2013, 07:36 am
  3. Replies: 1
    Last Post: 27th Apr 2012, 06:38 am
  4. Lisp routine to print layout tabs and exclude model tab
    By jason_a in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Nov 2010, 08:28 pm
  5. Print Tab Names When Publishing
    By Seann in forum AutoCAD General
    Last Post: 11th Sep 2009, 03:39 pm
Tags for this Thread
