Results 1 to 3 of 3
    Full Member hcostanzo's Avatar
    hcostanzo's Computer Details
    Windows 7
    Civil
    hcostanzo's Discipline Details
    Civil
    worked in the Structural field for 5.5 years, now learning the ins and outs of civil work
    Civil 3D 2016
    Sep 2012
    Colorado, USA
    32
    Question Rotated text in custom linetype won't center
    I've created my first line type (woohoo!) but the rotated V that I used as an "arrow" won't center and I'm having a difficult time understanding why so that I can fix it. I am aware that linetypes like the one I created exist but I wanted the arrows a specific size and distance apart which I couldn't do with the existing linetypes available to me (also I really wanted to try creating a custom one).
    In the attached picture:
    -the green line is the finished custom linetype
    -the red lines are polylines
    -the blue text is rotated 90 degrees, set to a text style titled Linetype (simplex font, not annotative, height set to 0 and width set to 1.0), and Justify set to Bottom Center
    linetypes-Model.pdf
    The finished linetype code is:
    *STREAM_LINE_W_ARROW_BIG,Stream_Line_W_Arrow_Big
    A,.392629,["V",Linetype,y=-.07619,s=.2,u=90],.207371,-.144393,.011213,-.138787,.011213,-.138787,.011213,-.144393,.392629,["V",Linetype,y=-.07619,s=.2,u=90],.207371
    Also, this the first time I've attached a picture, I'm not sure that I did it correctly, please excuse my lack of know-how on this. I will look into it further for future use.
    Any help is greatly appreciated and thank you in advance!
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,736
    I would have used a different technique and gone with the MKSHAPE and MKLTYPE commands found in Express Tools.
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,105
    Quote Originally Posted by hcostanzo View Post
    Several comments:-
    If you make a custom linetype with a named Textstyle, then that Textstyle has to be loaded into a new drawing before you can use that linetype in a new drawing.
    I am not sure whether the Bottom Centre justification does any good in this case. I would prefer to finely adjust the position of the character with the x and y factors (I see that you do not have an x factor in the definition).
    You are using the u factor. this means that if you draw a circle with this linetype, then halfway round, the arrow will change direction. Also the u factor does not convert down to earlier versions. I would prefer to use the r factor.
  1. Curve text in custom linetype
    By archie16 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 8th Jan 2013, 08:43 pm
  2. Custom linetype with text display problem
    By freek in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 25th May 2012, 02:05 pm
  3. Text in Rotated viewports
    By jquackenbush in forum AutoCAD Drawing Management & Output
    Last Post: 7th Feb 2012, 10:23 pm
  4. custom linetype text orientation issue
    By toberino in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Mar 2011, 07:57 am
  5. Rotated text in in layout
    By Lichado in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 25th Sep 2008, 02:59 pm
Tags for this Thread
