3d drawing process framework
Jeff Kite
I'm in a position now where I have no training or support. I'd like to learn how to draw a simple building with a vertical walled hole next to it.
I already have a ground surface, hole surface, and the grading surfaces for backfilling the sides of the hole and some ramps to get in and out of the hole. The building floor and roof need to slope towards the hole.
I'd like to end up with an isometric view with shaded walls and roof. The only 3d command I have used is presspull and it seemed useful. Is there a thread here that explains the most efficient ways to change views, draw a building, and shade vertical walls.
I am using Civil 3D 2010 and will switch to Civil 3D 2012 before the end of the year.
