usmantee Posted April 25, 2013 Share Posted April 25, 2013 My Menu bar for AutoCAD Civil 3D, 2012 is not showing. when I used the command "MENUBAR" or using the dropdown list from the task bar, the only thing that appear in the position of menu bar is "Expres" instead of "File" e.t.c. How can I get the menu bar back please? Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 25, 2013 Share Posted April 25, 2013 Have you tried changing or resetting your Profile? Quote Link to comment Share on other sites More sharing options...
usmantee Posted April 25, 2013 Author Share Posted April 25, 2013 No. I did not try that. Actually, I don't even know how to. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 25, 2013 Share Posted April 25, 2013 Do you have something called OPTIONS on your menu browser? Quote Link to comment Share on other sites More sharing options...
usmantee Posted April 25, 2013 Author Share Posted April 25, 2013 No. I don't have that. Quote Link to comment Share on other sites More sharing options...
BlackBox Posted April 25, 2013 Share Posted April 25, 2013 Have you considered either restoring your custom workspace, or using the CUI Editor? Quote Link to comment Share on other sites More sharing options...
Guest AARi Posted April 26, 2013 Share Posted April 26, 2013 (edited) Pick up in the drawing area with teh right-mouse botton, the last command has to be : OPTIONS [or just write down OPTIONS in the commandLine] Then check PERFIL/TAG and reset your profile..... in any case it´s a bit strange than MENUBAR does not work.. perhaps you are working in non-english AutoCad, so MENUBAR will not works, try help to find the correct command [barmenu, menuload, cargarmenu...] Profile/tab............. sometime i have not autocad opened... Edited April 26, 2013 by AARi Quote Link to comment Share on other sites More sharing options...
Murph_map Posted April 26, 2013 Share Posted April 26, 2013 Pick up in the drawing area with teh right-mouse botton, the last command has to be : OPTIONS [or just write down OPTIONS in the commandLine]Then check PERFIL/TAG and reset your profile..... in any case it´s a bit strange than MENUBAR does not work.. perhaps you are working in non-english AutoCad, so MENUBAR will not works, try help to find the correct command [barmenu, menuload, cargarmenu...] I think you mean "Profile Tab" not PERFIL/TAG. Quote Link to comment Share on other sites More sharing options...
Tyke Posted April 26, 2013 Share Posted April 26, 2013 Pick up in the drawing area with teh right-mouse botton, the last command has to be : OPTIONS [or just write down OPTIONS in the commandLine]Then check PERFIL/TAG and reset your profile..... in any case it´s a bit strange than MENUBAR does not work.. perhaps you are working in non-english AutoCad, so MENUBAR will not works, try help to find the correct command [barmenu, menuload, cargarmenu...] Profile/tab............. sometime i have not autocad opened... If you are not working with an English language version of AutoCAD prefix all English commands with an underscore character, "MENBAR" becomes "_MENUBAR". Quote Link to comment Share on other sites More sharing options...
Murph_map Posted April 26, 2013 Share Posted April 26, 2013 If you have only the Express menu showing then the menubar is working, you just have editted the CUI or something to remove the C3D and AutoCAD menus. Either a restart will fix and maybe you will need to load the cuix (menu) for C3D. Type in CUILOAD and see if those are loaded. Quote Link to comment Share on other sites More sharing options...
Guest AARi Posted April 30, 2013 Share Posted April 30, 2013 Express Tools in Civil 3D 2013.pdf 0.MACRO_CARGAR_ARX-LSP-FAS.pdf AARi Quote Link to comment Share on other sites More sharing options...
