Results 1 to 3 of 3
    Full Member
    Electrical
    btraemoore's Discipline Details
    Electrical Designer
    Electrical
    AutoCAD 2012
    Apr 2012
    Houston
    60
    Default simple simple... connecting to 2006 via interop
    okay, im trying to get a connection to 2006 and im having problems. i used keen(through the interface) example and its throwing a COM exception, BUT it is creating the instance of autocad. I dont think it is connected to it, but it creates it.
    NOW, when i downloaded the objectARX for 2006 there where no interop.dll's just the 3 "acdbmgd" variations... im just learing how to work with c#. Can some one throw me a little bone here here is my code.
    Code:
    public MainForm() {
    			InitializeComponent();
    			IMessageFilter oldFilter = default(IMessageFilter);
    			CoRegisterMessageFilter(this, oldFilter);
    			AcadApplication acApp = GetAcApp("AutoCAD.Application.16.2");
    		public AcadApplication GetAcApp(string progID){
    		AcadApplication acApp = null;
    		try {
    			acApp = (AcadApplication)Marshal.GetActiveObject(progID);
    		} catch {
    			try {
    				Type acType = Type.GetTypeFromProgID(progID);
    				acApp = (AcadApplication)Activator.CreateInstance(acType,true);
    			} catch {
    				MessageBox.Show("Cannot create object of type \"" + progID + "\"");
    		if (acApp != null) {
    			// By the time this is reached AutoCAD is fully
    			// functional and can be interacted with through code
    			acApp.Visible = true;
    			return acApp;
    		return null;
    Luminous Being BlackBox's Avatar
    BlackBox's Computer Details
    Windows 8.1 Professional, Server 2012 R2 Datacenter
    Dell Precision T3600
    Hex-Core Intel Xeon 3.2Ghz
    32GB
    3GB NVIDIA Quadro K4000
    2 x 240GB Samsung EVO SSD (RAID 0)
    1TB Western Digital VelociRaptor 10K RPM
    Dual 24" Dell Ultrasharp Widescreen Monitors
    Civil
    BlackBox's Discipline Details
    Senior Civil Designer
    Civil
    Public/Private Land Development, Transportation, and Utilities.
    Civil 3D 2016
    Nov 2009
    5,282
    It sounds like you're attempting to create a stand-alone EXE, in lieu of a plug-in (an assembly that is loaded into an active session of AutoCAD), is this correct?
    If instead you're after a plug-in, and you're already coding in C#, why not just use the .NET API (AcDbMgd.dll, AcMgd.dll) in lieu of COM?
    "Potential has a shelf life." - Margaret Atwood
    AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized Developer
    Sincpac C3D ~ Exchange Apps ~ Autoloader ~ AutoCAD Security
    Full Member
    Electrical
    Electrical Designer
    Electrical
    AutoCAD 2012
    Apr 2012
    Houston
    60
    I would like to learn both using the .NET API and COM. I have had a really hard time finding some good examples that explain verbosely about both. If you know where i can find any i would be very appreciative.
  1. Simple program. Simple answer
    By Hasan Faruk in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Apr 2013, 02:58 pm
  2. simple one
    By alijahed in forum AutoCAD General
    Last Post: 23rd Oct 2008, 12:56 am
  3. simple hopefully
    By russell84 in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th May 2008, 03:13 am
  4. A simple way to do this?
    By George Duls in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Dec 2007, 03:27 pm
  5. Simple simple, huh? rectangles how are they built?
    By Anna_here in forum AutoCAD Beginners' Area
    Last Post: 2nd Aug 2006, 09:18 pm
Tags for this Thread
