mntman552 Posted April 28, 2013 Share Posted April 28, 2013 I was wondering the best way to draw a circle that passes through an endpoint of a line and then is tangent to another circle above it? I need to create a radius of 3.5 between the two points. I will try to attach the picture Engelhaupt_SensorMount.dwg Quote Link to comment Share on other sites More sharing options...
JD Mather Posted April 28, 2013 Share Posted April 28, 2013 See attached. Quote Link to comment Share on other sites More sharing options...
mntman552 Posted April 28, 2013 Author Share Posted April 28, 2013 ok I did that no how can I trim the upper R3.5 so that the only portion remaining is what is between the top circle and the verticle line? I tried to trim it, but it says that it needs to intersect twice. Thanks for the help on the circle Quote Link to comment Share on other sites More sharing options...
JD Mather Posted April 28, 2013 Share Posted April 28, 2013 Trims fine for me? Attach your new file here. Did you pick both the vertical line and the circle as cutting edges for trimming the arc? Quote Link to comment Share on other sites More sharing options...
mntman552 Posted April 28, 2013 Author Share Posted April 28, 2013 I am not sure what is going on. Could something not be set up right in AutoCAD? We had a computer in class that wouldn't trim right and the professor had no idea what was going on he had never seen anything like it. Thanks for your help. Engelhaupt_SensorMount.dwg Quote Link to comment Share on other sites More sharing options...
mntman552 Posted April 28, 2013 Author Share Posted April 28, 2013 Never mind I got it figured out, I had to push shift while I selected the second one. I have never had to do that while at class, but for some reason I need to do it on my laptop at home. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted April 28, 2013 Share Posted April 28, 2013 Uncheck this under Options Quote Link to comment Share on other sites More sharing options...
mntman552 Posted April 28, 2013 Author Share Posted April 28, 2013 Thank you for your expertise. I should buy you a beer. I am getting too damn old to figure this stuff out. Quote Link to comment Share on other sites More sharing options...
Rabid Posted October 6, 2013 Share Posted October 6, 2013 See attached.[ATTACH=CONFIG]41648[/ATTACH] Can you pleas explain how you got this? EDIT: Looked at it a little longer. Does this work because the 2 reference circles are 3.5 in from where they touch? Quote Link to comment Share on other sites More sharing options...
Chilidawg Posted October 10, 2013 Share Posted October 10, 2013 The wierdest thing just happened to me. I was reading through the lists of posts, not having been on site for a while, and as I scanned the title of this thread, for the very, very briefest of moments, I though that it said: "drawing a circle that is tangent to another circle and passes through an elephant" Quote Link to comment Share on other sites More sharing options...
JD Mather Posted October 10, 2013 Share Posted October 10, 2013 dawg - what was in that chili? Quote Link to comment Share on other sites More sharing options...
