Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 49
  1. #11
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    At first look - it looked pretty good.
    But on closer inspection -
    -you are a long way from origin and outside of border.
    -I would place border in paperspace layout.
    -I placed a couple of isocircles and yours did not match radius of mine
    - you have several places that aren't trimmed correctly.
  2. #12
    Junior Member
    AutoCAD 2012
    Oct 2012
    20
    Thanks, i mainly concerned about the accuracy of the model itself as i have a border/template to add later.
    Can you highlight the drawing errors and send back to me???
    Im really stuck !!
  3. #13
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Your radii are wrong and in the plan view that rectangle is not only in the wrong position it also requires at least one extra line. Try again.
    See where it says, for example, R30? That is the radius for the segment of the circle on the outside of the object. In your drawing the radius is 33. Same goes for all the others.
  4. #14
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Maybe this view will be better.
    Jeez, load times today are terrible. What gives? Takes forever.
  5. #15
    Junior Member
    AutoCAD 2012
    Oct 2012
    20
    Hi Remark,
    Thanks for your comments, its the isometric that im really concerned about.
    Can you/anyone see any probs with isometric.
    If someone could highlight any issues i have and then send me the dwg back it would be good.
    Thanks
    Matt
  6. #16
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    It seems useless to model in isometric in this century when it is so much easier to model in 3D.
    I'm sure you are just (trying) to follow instructions, but it would be a bit of work (torture) to create the solution file.
    Maybe someone else will come along and create key.
  7. #17
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Well just for fun I gave it a go as a 2d isometric. Not an impossible problem (I am confident in my solution), but I will make a small wager that your instructor can't do it absolutely correctly. (if you don't give the instructor a warning that I am checking, I might even be willing to make the wager even if the instructor does know I am checking their "solution")
    I suspect by the time the instructor finishes the "solution" he/she will say, now let's move on to the modern 3D tools.
  8. #18
    Junior Member
    AutoCAD 2012
    Oct 2012
    20
    Hi JD
    Thanks for your reply, can you post your Iso dwg file.
    I'm really looking to see if someone can post there ISO so I can use it as a proof check.
    Can you help?
    In willing to PayPal someone for there time if they can produce an exact replication of the scanned picture in the previous page.
    Thanks
    Matt
  9. #19
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Your plan or top view of the object was wrong therefore I expect your isometric would be wrong too (and it was). Did you redraw it or not?
  10. #20
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    I believe this is the isometric view you are looking for.
  1. Replies: 21
    Last Post: 14th Jul 2014, 07:04 am
  2. Replies: 1
    Last Post: 4th Oct 2012, 12:40 pm
  3. Replies: 0
    Last Post: 5th Sep 2012, 05:33 am
  4. drawing "by block" not "by layer"
    By DoctorDrake in forum AutoCAD General
    Last Post: 8th Mar 2012, 09:21 pm
  5. Replies: 1
    Last Post: 25th Nov 2009, 06:35 pm
