rulesurf twists surface
Cadflock
when I try to use rulesurf between 2 circles on an angled plane, the surface twists instead of drawing a cylinder. Any suggestions??:cry::?
I'm assuming the circles have different diameters. Have you tried the LOFT command?
Can you attach a copy of the drawing to your next post?
Is there a reason you are using rulesurf rather than one of the more modern tools (post r2007)?
If you really really really want a cylinder (cut at an angle) I think you will need to extrude or revolve and then slice or subtract.
