transcad Posted May 1, 2013 Share Posted May 1, 2013 Is it possible to check if, in a drawing, there are some objects drawn with Intellicad? How? Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 3, 2013 Share Posted May 3, 2013 Block comparison. One block was created in IntelliCAD and inserted into an AutoCAD drawing already containing a block. A "List" is performed on both blocks. Other than the name can you tell which block was created with a different program? Command: li LIST Select objects: 1 found Select objects: BLOCK REFERENCE Layer: "0" Space: Model space Handle = 1bc Block Name: "INTEL_Block" at point, X= 13.2706 Y= 10.9050 Z= 0.0000 X scale factor: 1.0000 Y scale factor: 1.0000 rotation angle: 0 Z scale factor: 1.0000 InsUnits: Inches Unit conversion: 1.0000 Scale uniformly: No Allow exploding: Yes Command: LIST Select objects: 1 found Select objects: BLOCK REFERENCE Layer: "0" Space: Model space Handle = 1c4 Block Name: "ACAD_Block" at point, X= 23.8775 Y= 11.8964 Z= 0.0000 X scale factor: 1.0000 Y scale factor: 1.0000 rotation angle: 0 Z scale factor: 1.0000 InsUnits: Inches Unit conversion: 1.0000 Scale uniformly: No Allow exploding: Yes Perhaps a DXF file could be created and checked to see if the difference could be spotted there but I don't have the time to test that theory. You are welcomed however to conduct such a test and report the results back here. We await your reply. Quote Link to comment Share on other sites More sharing options...
