Black region appears in paper space...
Gjay001
Hi, I have an issue with a file when I plot only.
The black 'mask' appears only after plotting. It does not show up in print preview.
There are no frozen layers or switched off through viewports.
When I open the viewport on a new paperspace page it follows me in. I can only assume there is an underlying mask in model space or paperspace.
Thank you for reading my question and your help is very much appreciated.
George.
Sounds like you may have a Wipeout in your drawing. :unsure:
Type WIPEOUT at the command prompt and then type "F" for Frames and then "ON" to enable the Wipeout frame to be displayed. Do you now see a rectangle where the black region displays on your printout? If so, select it and delete it.
