+ Reply to Thread
Results 1 to 9 of 9
  1. #1
    Senior Member Orbit's Avatar
    Using
    not applicable
    Join Date
    Dec 2002
    Posts
    167
    Default Copy to Clipboard / Copy with Base Point not working
    I have trouble with mentionate it Copy- Paste of a 2D dwg. Whenever I try it happens nothing. I did not make any modifications of the dwg. So I have no idea why AutoCad is behaving so rude.
    I need help ASAP and any solution is welcome. I need to try everything at this moment.
    Thank you in advance for help
  2. #2
    Flores
    Default
    What are you pasting into? If ACAD, if you don't have time to figure it out, wblock what you need, then insert it into your other drawing.
    Flores
  3. #3
    Super Moderator f700es's Avatar
    Computer Details
    f700es's Computer Details
    Operating System:
    Windows 7 Pro (W)/Windows 7 Home Premium (H)
    Computer:
    Lenovo ThinkStation D20 (W)/ Dell Inspiron 570 (H)
    Motherboard:
    Intel (W)/AMD (H)
    CPU:
    Intel Xeon E5503 (W)/AMD Athlon 2 X4 (H)
    RAM:
    4 GB DDR3 (W)/ 6GB DDR3 (H)
    Graphics:
    nVidia Quadro FX 580 (W)/nVidia GF GT430 (H)
    Primary Storage:
    500 GB HDD (W)/1 TB (H)
    Secondary Storage:
    Seagate FreeAgent Go 320gb
    Monitor:
    Samsung P2770HD 28" LCD and Samsung B2430 (W)/Dell 22" LCD (H)
    Discipline
    Facilities Mgmt
    f700es's Discipline Details
    Occupation
    Space Database Admin
    Discipline
    Facilities Mgmt
    Details
    Archibus Management
    Using
    AutoCAD 2013
    Join Date
    Sep 2002
    Location
    Winston-Salem, NC - USA
    Posts
    4,509
    Default Re: Copy to Clipboard / Copy with Base Point not working
    Quote Originally Posted by Orbit
    Could it be the windows accelerator keys option is un checked?
    Please do not PM me with CAD questions. Post your question on the forum. Our users are the best out there and you'll get the best possible answer to your question.
    - http://f700es.deviantart.com/gallery/ -
  4. #4
    Using
    not applicable
    Join Date
    Dec 2002
    Posts
    167
    Default
    Thank you folks. I have tried your suggestions and it happens nothing. Even in the wblock case. I have trouble only with this particular dwg.
    I post it my message when I lost my initiative and imagination to solve the rpoblem.
    I can go on working on the dwg. but when it comes to copy/paste into another dwg. does not work. What on Earth happened?
  5. #5
    Super Member
    Using
    Architectural DT 2007
    Join Date
    Dec 2002
    Location
    London
    Posts
    1,087
    Default
    What if you do any of the following:
    Select the drawing and drag the contents into new drawing?
    How about XREF the contents to another drawing?
    I guess you have purged and checked the drawing for errors.How do you copy and paste?Do you use the windows shortcuts CTRL+C for copy CTRL+V for paste,maybe they have been redefined?
  6. #6
    Super Member Mr T's Avatar
    Using
    AutoCAD 2007
    Join Date
    Nov 2002
    Location
    Loch Oich SCOTLAND...
    Posts
    1,641
    Default
    try DXFOUT and then DXFIN to take bits out to another DWG etc.
    Nick
    http://www.flickr.com/photos/80049703@N00/ http://mtbnick.fotopic.net/
    http://s240.photobucket.com/albums/ff241/dyNick_Scots/
    http://designgraphicsshowcase.blogspot.com/
    High School Classroom - 21 AutoCAD 2007, Inventor 11, COREL Draw & Paint 11. Very Unreliable Network.
    Home - AMD 2.1GHZ - 512Ram, 64 Video,
    Laptop Inventor 7, Autocad 2004, Corel 11
  7. #7
    Using
    not applicable
    Join Date
    Dec 2002
    Posts
    167
    Default
    I think I figured out what is happening. The dwg. in cause went backward and forward between ACD2000 and 2004. Still something does not work well. Anyone encounting the same or another similar inconvenince as in above case?
    I am going to try Mr. T solution and let you knnow how it works.
  8. #8
    SpeedCAD
    Default
    I imagine that you have a virus called BLASTER. These virus don't let operate with COPY and PASTECLIP in AutoCAD and others programs...
    I hope that you solve the problem...
  9. #9
    Super Member
    Using
    Join Date
    Dec 2002
    Location
    London
    Posts
    1,087
    Default
    nasty,have a look at this:
    http://securityresponse.symantec.com...ster.worm.html
    might help if not,when ive got some spare time ill see what else i can dig up.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
