zeddydee Posted May 9, 2013 Share Posted May 9, 2013 Hi guys, Just trying to create a transition, with the thickness shown, from one sketch to another. Kind of confused, I thought this was a loft operation. Quote Link to comment Share on other sites More sharing options...
zeddydee Posted May 9, 2013 Author Share Posted May 9, 2013 Also should they be in the same sketch? Quote Link to comment Share on other sites More sharing options...
zeddydee Posted May 9, 2013 Author Share Posted May 9, 2013 Okay so I resolved that lol... but now how do I create a plane at a 45 degree angle.. What I'm trying to do is create a handle, initially the first part juts out normally but then the second part of the handle is 45 degrees to the other part... Quote Link to comment Share on other sites More sharing options...
stevsmith Posted May 20, 2013 Share Posted May 20, 2013 You don't need to create a plane at 45 degrees, use the "yellow" highlighted plane and create a "side view" sketch on that, then extrude. Hopefully that should help you. Quote Link to comment Share on other sites More sharing options...
