Results 1 to 2 of 2
    Forum Newbie
    Architecture 2009
    May 2013
    2
    Default Plotting with lines hidden
    Im trying to plot a 3D object in Autocad 2009 but can't remove the hidden lines.
    The "Hide" command removes the appropriate lines in the viewport and in the print preview but the print-out still appears with all the lines.
    Full Member
    AutoCAD LT 2011
    Nov 2012
    Ireland
    72
    I'm not near my computer right now. But I think if you select the viewport and right-click and then select hidden it should sort it out for you. I also think that there are two options to select 'hidden' in the drop down list, so try both of them.
  1. Plotting a veiwport with hidden lines works but when I go to re print they are solid
    By cfrydawg in forum AutoCAD Drawing Management & Output
    Last Post: 14th Feb 2012, 03:16 pm
  2. Hidden Lines won't stay hidden when plotting
    By jonesy4000 in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Aug 2011, 04:07 pm
  3. Plotting hidden lines AutoCAD 2012
    By ServaCleanCAD in forum AutoCAD Drawing Management & Output
    Last Post: 14th Jun 2011, 08:09 pm
  4. Constructing Hidden Lines and Construction Lines
    By Colgrave in forum AutoCAD Beginners' Area
    Last Post: 6th Feb 2009, 04:01 pm
  5. Hidden lines, not being hidden in 3D view
    By deadseasquirrels in forum AutoCAD 3D Modelling & Rendering
    Last Post: 4th Sep 2003, 11:08 am
Tags for this Thread
