Page 2 of 10 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 92
  1. #11
    Senior Member welldriller's Avatar
    welldriller's Computer Details
    Windows 10 Home
    Dell inspiration 3650
    x64 processor
    8 GB
    Dell P190SB#4
    Solidworks 2017
    Jan 2013
    Federalsburg, Maryland
    311
    CAM DRWG.jpgMr Mather Your drawing looks a heck of a sight better than mine but would like for some one to look at it for me.
    i know that i am .01 off in the center but what else
  2. #12
    AARi
    ]0000000000
  3. #13
    Super Member
    AutoCAD 2012
    Jun 2012
    902
    Quote Originally Posted by JD Mather View Post
    If we assume all of the arcs are tangent and they stop/start at the angles given - there is one solution. (none of the arc centers are on any of the construction lines, but it is fully defined with the given dimensions)
    Sounds right.
    (BTW - solution was found in less than 10 minutes.)
    In AutoCAD? Seems like someone guessed you would resort to Inventor. Hopefully, AutoCAD can do it, as well. Please post the DWG and explain. I can see how you can constrain the arcs to be coincident and tangent to each other. How did you determine the exact location of the shaft per the given angles? It looks like these are all interdependent and might require trial and error.
    When all you have is a hammer, everything looks like a nail.--
    “Doc, it hurts when I do this.” “Well, don’t do that!”
    “Well, if you don’t know, I’m certainly not going to tell you!”
  4. #14
    Super Member
    AutoCAD 2012
    Jun 2012
    902
    Quote Originally Posted by AARi View Post
    in microstation....
    Are you saying you could not do it in AutoCAD? Where is the center of your shaft? Were you able to locate it per the problem?
  5. #15
    AARi
    0000000000
  6. #16
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Quote Originally Posted by neophoible View Post
    Sounds right.
    In AutoCAD? Seems like someone guessed you would resort to Inventor. Hopefully, AutoCAD can do it, as well. ..
    The solution would be identical in AutoCAD - using parametric geometry constraints.
    At some point I will try to get around to producing an AutoCAD solution - it is just much faster for me to work in a modern CAD program.
    Here is the AutoCAD r2013 edu solution.
    Put the hole for the shaft at the origin (0,0,0) I didn't bother with the trivial.
    Cam Solution.dwg
  7. #17
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    ...seems somthing wrong ...
    I don't see the specified angles in your "solutions" that were given in the original problem?
    Can you turn off the grid in those programs to make it easier to visualize?
  8. #18
    Super Member
    AutoCAD 2012
    Jun 2012
    902
    Understood. Working out the solution is not quite identical, though, is it? If I ever get a modern computer, maybe I'll switch to a modern program!
    Thanks, JD. I'll try to take a look when I get a chance to convert it to an earlier DWG format. If by trivial, you mean drawing the shaft hole, agreed. If you mean locating it to begin with, well, that seems to me to be a major part of the prob. In fact, it's crucial, as that is where all of the angles are being measured from, right? It seems to me that there would be no unique solution without it.
  9. #19
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    The solution is identical. Working out the solution is almost identical. AutoCAD doesn't automatically add coincident constraint to trimmed entities while Inventor does - cuts down on the amount of work a bit (AutoCAD solution took me 24 minutes, working on a laptop, would have been less on my desktop with dual screen larger monitors).
    I would have saved down myself, except that parametric constraints are critical to the way I found the solution.
    Rather obvious that it is a circle at the vertex of the angled lines. (keyway is also trivial)
    I applied a Fixed constraint at the vertex (at the origin). If the fixed constraint is removed the entire cam can be dragged around the screen without distortion using any point as it is fully constrained (the position constraint being the only one defined by Fixed).
  10. #20
    AARi
    0000000000
  1. How to draw this ?
    By elka in forum AutoCAD Beginners' Area
    Last Post: 15th Jun 2011, 12:46 pm
  2. how to draw this.. pls help me..
    By chaarr in forum AutoCAD Beginners' Area
    Last Post: 19th Jan 2010, 08:18 am
  3. How do I draw this?
    By Mason Dixon in forum AutoCAD Beginners' Area
    Last Post: 16th Jan 2010, 03:20 am
  4. How do I Draw this?
    By zetnie in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 14th Mar 2008, 06:10 pm
