Page 3 of 10 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 92
  1. #21
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    Your "solution" does not appear to be even close to correct.
    Before all else, you should draw and dimension the angled lines - I do not see these in your solution. (lengths of the lines don't matter for the solution - make them extra long so that they can be used for trimming the arcs as needed)
    It makes sense to place the vertex of the lines at the origin.
    As I noted previously - NONE of the arc centers are on ANY of the given lines (nor are they at the origin).
    That makes it an interesting geometry problem.
  2. #22
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,883
    AFAIK AutoCAD 2009 (OP's version) doesn't have constraints.
  3. #23
    Super Member
    AutoCAD 2012
    Jun 2012
    902
    Quote Originally Posted by JD Mather View Post
    Rather obvious that it is a circle at the vertex of the angled lines. (keyway is also trivial).
    Yes, that's what I said. But the center of it is not trivial, it is key, that is, it is whence the angled lines originate. Without it, they no longer have an origin in the original problem. Or am I missing something? The reason I say this is that, the way I understand this, these angles are not the angles of the arcs, but of the endpoints to the center of the shaft, that is, to the point of rotation.
    I would have saved down myself, except that parametric constraints are critical to the way I found the solution.
    Yes, I can see that the parametric constraints are critical. I'm working in 2012, but save down to 2007 format due to work environment constraints. I think that the 2012 parametric constraints are retained when saving, though they may not actually work in 2007. Does anyone know if there are new parametric constraints in 2013 compared to 2012?
    Last edited by neophoible; 14th May 2013 at 11:00 pm. Reason: added "The reason..."
    When all you have is a hammer, everything looks like a nail.--
    “Doc, it hurts when I do this.” “Well, don’t do that!”
    “Well, if you don’t know, I’m certainly not going to tell you!”
  4. #24
    Super Member
    AutoCAD 2012
    Jun 2012
    902
    Quote Originally Posted by SLW210 View Post
    That would make this a very difficult problem for him indeed!
  5. #25
    Super Member Bill Tillman's Avatar
    AutoCAD 2018
    Oct 2008
    Miami, FL
    1,273
    So JD, can you tell me if I got it correct? I took me less than 10 minutes as well using AutoCAD.
    It's deja vu, all over again.
  6. #26
    Super Member
    AutoCAD 2012
    Jun 2012
    902
    Quote Originally Posted by Bill Tillman View Post
    Bill, you did it the way I initially interpreted it, which is not correct. If you look at the endpoints of your arcs, they do not lie on the angled lines you drew. As I mentioned to JD, and as he apparently drew it, these angles represent how much rotation each arc sees about the center of rotation of the cam, not the angles of the arcs themselves.
    BTW, it looks like AARi's microstation solution may be correct and match JD's, but it is very hard to tell.
    Last edited by neophoible; 15th May 2013 at 12:00 am. Reason: added note about AARi's solution
  7. #27
    AARi
    0000000000
  8. #28
    Senior Member welldriller's Avatar
    welldriller's Computer Details
    Windows 10 Home
    Dell inspiration 3650
    x64 processor
    8 GB
    Dell P190SB#4
    Solidworks 2017
    Jan 2013
    Prince George, Va.
    303
    Ok no reply on an amateurs post (POST #11) on page 2 It was done in Autocad LT 2000.
  9. #29
    AutoCAD 2018
    Oct 2008
    Miami, FL
    1,273
    Quote Originally Posted by neophoible View Post
    Bill, you did it the way I initially interpreted it, which is not correct. ...
    I didn't think it would have been that easy. But what I see when I trim the arcs to the angled lines, I'm left short on the left side with the arc which is 47.3R so if I extend it to the angled line to meet the other arc, the surface does not follow a smooth transistion. Again, I'm no ME and never work with cams, but that would seem to me that your push rod would have a rough time hitting this surface imperfection. Am I off-base on this too?
    BTW all my arcs end on the angled lines with the exception of the 47.3R line in the upper right portion of the cam.
  10. #30
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    I don't see an attachment?
    Did you look at my solution? Every arc is tangent on both ends. Every arc begins and ends on the lines. (but the centers are not on the lines)
  1. How to draw this ?
    By elka in forum AutoCAD Beginners' Area
    Last Post: 15th Jun 2011, 12:46 pm
  2. how to draw this.. pls help me..
    By chaarr in forum AutoCAD Beginners' Area
    Last Post: 19th Jan 2010, 08:18 am
  3. How do I draw this?
    By Mason Dixon in forum AutoCAD Beginners' Area
    Last Post: 16th Jan 2010, 03:20 am
  4. How do I Draw this?
    By zetnie in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 14th Mar 2008, 06:10 pm
