Openantics Posted May 12, 2013 Share Posted May 12, 2013 I am currently building a surface from a Lidar data set and i have about 2M points in a XYZ file. Using the Point Clouds function in Propector, I followed the C3D dialogue boxes to create a database, and then used the create surface function. question: the surface doesn not use all the points?? when i turn on points in the surface style, there are many lidar points not included. I found the Point Density slide bar, and then read this in the help file: The system variable value is a percentage of 1,500,000, which is the maximum number of points that can exist in a drawing, regardless of the number of point clouds attached to a single drawing. I have many more points to import to this surface, so does this mean i have to build several surfaces? Actually the Lidar data set has 1.7M points, so i am not sure why i am at least not seeing 1.5M added to the surface Also, the Point Cloud Properties show the following stats: Point Cloud Object Maximum number of points displayed: 882051 Point Cloud Database Total number of points: 1764050 very interesting!! thanks for any more help! OA Quote Link to comment Share on other sites More sharing options...
Guest AARi Posted May 13, 2013 Share Posted May 13, 2013 I have many more points to import to this surface, so does this mean i have to build several surfaces? i will do that if you don´t want to lose info. Check always the elevation of all of them [if all are in the correct-range] Quote Link to comment Share on other sites More sharing options...
