Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: Measuring areas
    Full Member
    rusty's Computer Details
    Win7
    Dell T3500
    Xeon
    8
    Civil 3D 2011
    Nov 2005
    Trondheim, Norway
    47
    Default Measuring areas
    I need to calculate the areas within a set of lines that form a closed area.
    1. How do I do that?
    2. Do I need to create a polyline around the area, or is lines enough?
    I use AutoCad Map 2000i
    Thanks in advance
    Administrator CADTutor's Avatar
    CADTutor's Computer Details
    Windows 7 Home Premium 64bit
    Asus P7P55D-E PRO
    Intel Core i7-860
    4GB PC3-12800 C8 Corsair Dominator
    NVIDIA Quadro FX 1800 768 MB
    Intel X25-M SSD 160GB
    Samsung Spinpoint 320GB
    BenQ FP241W 24" Wide
    Education
    CADTutor's Discipline Details
    Senior Lecturer (Digital Design), Landscape Architect & Web Designer
    Education
    AutoCAD 2014
    Aug 2002
    Hampshire, UK
    3,607
    You cannot calculate the area bounded by lines, so you will need to use polylines. Check out the BOUNDARY command as this could be used to create closed polylines from your lines. Also have a look at the AutoLISP archive for a routine that will calculate total area from all polylines on a specific layer.
    http://cadtutor.net/forum/viewtopic.php?t=1505
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    AutoCAD Tutorials | How to add images to your posts | How to register successfully | Forum FAQ
    Senior Member fahim108's Avatar
    fahim108's Computer Details
    Windows XP Professional
    HP Pavilion dv5000
    Architectural
    fahim108's Discipline Details
    Architect
    Architectural
    AutoCAD 2012
    Apr 2006
    Mumbai, India
    491
    If the shape isn't much complicated, try using the AREA command. Then pick up all the corners (end points) of the shape, one by one, along the perimeter, and hit enter. Although this is a tedious process and doesn't work for curved boundaries, still knowing about it is better!
    Full Member
    Win7
    Dell T3500
    Xeon
    8
    Civil 3D 2011
    Nov 2005
    Trondheim, Norway
    47
    That should help a lot - Thanks!
  5. #5
    Senior Member
    AutoCAD 2004
    Apr 2006
    235
    I love this forum.
    never fails meh.
    Justin J. F. RamireZ - Drafter Extraordinaire
    Bryan/College Station, Tx
    REVIT MEP 2009, CAD MEP 2009, CAD LT '00 & '04, CAD 04
  6. #6
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,588
    Quote Originally Posted by slimjramirez
    I love this forum.
    never fails meh.
    :cat:
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
  7. #7
    Super Member Raggi_Thor's Avatar
    AutoCAD 2008
    Aug 2007
    Trondheim, NORWAY
    718
    It's an interesting question, even if it's old now.
    You can do it manually like this:
    Command: bo BOUNDARY + ENTER
    Select internal point: (Click)
    BOUNDARY created 1 polyline
    Command: area
    Specify first corner point or [Object/Add/Subtract]: o
    Select objects: last
    Area = 17500000.000, Perimeter = 17000.000
    Command: (/ (getvar "area") 1000000.0)
    17.5
    (This means the area in square meter is 17.5 if the drawing unit is mm)
    Or you can make a new button (Command: CUI) with a macro like this:
    ^C^C-Boundary;\;Area;O;Last;Erase;Last;;(/(getvar "area")1000000.0);
    The Lisp part doesn't work in LT (unless you install LT Extender).
    Normally you would make a block for room info if you are working with buildings. STATSBYGG in Norway has made a block for room number, function, area etc. that they demand that you use in their projects. They manage "all" public buildings in Norway.
    mvh, Kvedja, Kind Regards,
    Ragnar Thor Mikkelsen
    www.DESIGNDATA.no
  8. #8
    Forum Newbie
    AutoCAD 2011
    Mar 2012
    2
    Default block with attributes linked to an area
    Can anyone tell me how can I link block to an area so when I change the size of an area the values in block will update automatically?
  9. #9
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,494
    A block or a label?
  10. #10
    AutoCAD 2008
    Aug 2007
    Trondheim, NORWAY
    718
    Default Attdef + Field + Block
    These are the commands you use,
    ATTDEF to define the attributes.
    This command has the option to use a FIELD as a default value.
    In the FIELD dialog, select obect, select your pline, the select Area and formatting if you like.
    Then define your block.
    The problem is that all instances of this block, every insert, will be linked to that one pline you selected.
    I did this in Bricscad, but I bet AutoCAD is practically idential.
    Mvh, Kvedja, Kind Regards,
    http://www.DESIGNDATA.no/English.htm
