Results 1 to 4 of 4
    Tara
    Default Won't show smooth lines???
    I am working in a drawing that will not show me smooth lines. Splines show as cornered lines, dashed lines show as solid lines, circles as octogons etc.
    When I plot them however the are exactly as they should be.
    Why is this and can I turn off the setting that is making it behave this way?
    robfowler
    Click on the Tools menu, choose Options at the bottom of the dropdown list. Click on the Display tab when the Options window opens and change the setting for Arc and circle smoothness to 2000 (max is 20000).
    Alternatively type in VIEWRES at the command line and change the setting there.
    Also ensure SHADEMODE is set to 2D as circles don't always appear smooth when SHADEMODE is set to 3D.
    The reason Acad defaults to a low viewres setting is to allow faster regen of the screen. A circle is still a circle even though it is seen as a series of small lines. However I haven't noticed any deterioration in screen regen when I use a setting of 2000 but then I'm not working with massive files where this may be a problem.
    Rob.
    Administrator CADTutor's Avatar
    CADTutor's Computer Details
    Windows 7 Home Premium 64bit
    Asus P7P55D-E PRO
    Intel Core i7-860
    4GB PC3-12800 C8 Corsair Dominator
    NVIDIA Quadro FX 1800 768 MB
    Intel X25-M SSD 160GB
    Samsung Spinpoint 320GB
    BenQ FP241W 24" Wide
    Education
    CADTutor's Discipline Details
    Senior Lecturer (Digital Design), Landscape Architect & Web Designer
    Education
    AutoCAD 2014
    Aug 2002
    Hampshire, UK
    3,607
    Tara
    This is to do with View Resolution. You can set the value for this in one of two ways:
    From the pull-down, go to Tools>Options... When the Options dialogue appears, click the Display tab. In the right-hand column you will see a value for "Arc and circle smoothness". The default value for this in AutoCAD 2004 is 1000. It's likely that this value has been set much lower for the drawing you are using. The value can range from 1 up to 20,000 where 1 is lowest quality and 20,000 is highest quality.
    The second method is to use the command line. If you enter VIEWRES at the command prompt, you will be asked "Do you want fast zooms?". Answer "Yes" and then you will be able to enter a value just as above.
    You might wonder why bother having this setting at all. Well, the higher the view resolution, the harder AutoCAD has to work to display the drawing as you zoom and pan around and consequently the whole drawing experience can slow down, particulary on older machines or with very large drawings. It's not such an issue these days with very fast PC's but as with many aspects of AutoCAD, the old work-arounds for problems relating to large drawings and slow machines are still available.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    AutoCAD Tutorials | How to add images to your posts | How to register successfully | Forum FAQ
    Tara
    Default Got it!
    Thanks so much for your help! I got it working right now.
    After many hours of frustration mind you!
    Thanks again guys!
