spinecad Posted May 14, 2013 Share Posted May 14, 2013 How you do the draft angle of, for example, five-star-shaped object in AutoCAD? Thank you Example of the draft angle: http://www.custompartnet.com/image/glossary/draft-angle.png Quote Link to comment Share on other sites More sharing options...
JD Mather Posted May 15, 2013 Share Posted May 15, 2013 What is your desired draft angle? What is your desired height? Do you want it shelled as in your second image? If so, what is the wall thickness? Can you attach dwg for image 1 (the five-star-shaped) object. Quote Link to comment Share on other sites More sharing options...
