woodyken Posted May 18, 2013 Share Posted May 18, 2013 (edited) Is it possible to make a solid (that i can slice in autocad) from a *.skp ( 3d) file from sketchup. Can anyone tell me how to do this ? Thanks in advance Edited May 18, 2013 by woodyken Quote Link to comment Share on other sites More sharing options...
pqphillips Posted May 18, 2013 Share Posted May 18, 2013 (edited) If you have Sketchup installed (it's a free program), you can export to .dwg format. If you don't have Sketchup and don't want it, then given that you are using 2010, SKP Import for AutoCAD will probably work, though you may have to convert it to a 3D Solid afterwards, as it only converts to points, lines, polylines, 3D faces, or polyface meshes. Edited May 18, 2013 by pqphillips Quote Link to comment Share on other sites More sharing options...
woodyken Posted May 18, 2013 Author Share Posted May 18, 2013 I have sketup 8 pro on my computer and can export the skp file to a dwg drawing. But this is not a solid and i do not know how to covert it. I tryed with the command "convtosurface" but it didn't work. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted May 20, 2013 Share Posted May 20, 2013 Search around on here for some tips on converting them in AutoCAD. Start with the similar threads at the bottom of this thread. It is usually hit or miss depending on the acurracy of the .skp. Quote Link to comment Share on other sites More sharing options...
