angenel24 Posted May 22, 2013 Share Posted May 22, 2013 i was trying to make hidden line, i changed the line type to dashed hoping it would appear - - - - - in my drawing but it still appeared ______________ then for the plotting i was trying to plot my drawing in LAYOUT 2.. i used ZOOM then scale and used 1/300xp. i was aiming for 1:300 scale but it always appears bigger than expected and it wont fit in the paper.. i tried drawing it manually in piece of paper and it fits, but it cad it wont.. do help me plss:cry: Quote Link to comment Share on other sites More sharing options...
Guest AARi Posted May 22, 2013 Share Posted May 22, 2013 Check "ltscale" variable in your documentation may be help Quote Link to comment Share on other sites More sharing options...
mikekmx Posted May 22, 2013 Share Posted May 22, 2013 pita getting dashed lines to show properly sometimes if you havetrouble finding the correctscale, a method i sometimes use is draw a line in paperspace at a linetype scale of 1. will hopefully show correct. then change space it to model space, check the LTscale and modify any other lines pastor future to the same. sometimes you need to regen afterchanging an object's linetype scale to getit to show properly atthe new scale. Quote Link to comment Share on other sites More sharing options...
