dbroada Posted May 22, 2013 Share Posted May 22, 2013 I have just been given a set of drawings from another DO in our group. These drawings have an XREF defined with an absolute path, which is on another planet - well somewhere else anyway. What is the easiest way to convert this to a relative so that I can work on the drawings and then give them back to them? Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 22, 2013 Share Posted May 22, 2013 -XREF > Path option is what I think you are looking for. Quote Link to comment Share on other sites More sharing options...
dbroada Posted May 22, 2013 Author Share Posted May 22, 2013 that didn't quite do what I had intended but I can now see that I can remove the path from the current XREF manager and save it to give me what I want. Thank you for the starting point. I just hadn't seen it before. Quote Link to comment Share on other sites More sharing options...
dbroada Posted May 22, 2013 Author Share Posted May 22, 2013 its actually even easier than I thought. I had a set of 5 drawings looking for an xref in an obscure folder. I have changed just one drawing in the set to look in the current folder and all the rest changed by themselves. WooHoo! Result. (Still don't like using XREFs though) Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 22, 2013 Share Posted May 22, 2013 Now that wasn't so bad then after all was it? Glad to hear YOU figured it out because I had no clue! LoL Quote Link to comment Share on other sites More sharing options...
RobDraw Posted May 22, 2013 Share Posted May 22, 2013 Another option is to put the XREF in the same folder as the referencing file. No matter what type of pathing is assigned, AutoCAD automagically finds them. Quote Link to comment Share on other sites More sharing options...
dbroada Posted May 22, 2013 Author Share Posted May 22, 2013 Another option is to put the XREF in the same folder as the referencing file. No matter what type of pathing is assigned, AutoCAD automagically finds them.that's what happened here. I had the XREF in the folder with the drawings but they were all finding the XREF in their original folder, not the local one. Once I had told the first drawing to look in the current folder they all found the local one. Quote Link to comment Share on other sites More sharing options...
feargt Posted June 21, 2013 Share Posted June 21, 2013 you can also use the refernece manager to change the path to a relative path. Or use the express tool to "redir", this allows you to do search and replace for a specific path. Quote Link to comment Share on other sites More sharing options...
