mmp Posted May 24, 2013 Share Posted May 24, 2013 Hello I'm using AC 2011LT on a PC Every time I print to PDF or printer a line appears which is not visible on the model or paper space. It is even not visible when I preview the print before printing (again from model or paper). And on different layouts the line moves and sometimes doubles. I have done all the regular things - all layers on, all unfrozen, all visible, etc, I've purged, regened, made a save as file, gone to another persons computer but still the same problem. I did have this problem before on another file 2 years ago and fixed it but cannot remember how and have search the web to find the same solution. I need to issue this drawing today and would really appreciate any help to fix this. Thank you Images attached. Moj screen print of preview.pdf PDF from model space.pdf Quote Link to comment Share on other sites More sharing options...
Tyke Posted May 24, 2013 Share Posted May 24, 2013 Try purging your drawing using the command "-PURGE", without the quotation marks and don't miss off the dash at the beginning. Follow the prompts and select "ALL". Quote Link to comment Share on other sites More sharing options...
mmp Posted May 24, 2013 Author Share Posted May 24, 2013 never mind - problem fixed. I typed AUDIT at command line answered YES and the pesky line appeared in model space and I deleted it! Phew! Quote Link to comment Share on other sites More sharing options...
mmp Posted May 24, 2013 Author Share Posted May 24, 2013 Thank you for your reply - the AUDIT command worked though. Quote Link to comment Share on other sites More sharing options...
