what should i do revit
haseebsarwar42
hi,
if i am drawing a map in Revit Architecture and i need some structure drawing then what should i need to use Revit Structure or is there some other way?
thanks in adv
haseeb
To use Revit Structure, you need the software, a serial number and the knowledge to use the program.
if you have Revit 2013+, there's a one-box version that has all the disciplines within it.
Seeing as you're using RAC, I assume your computer is already up-to-snuff and can handle RST.
