Results 1 to 7 of 7
    Junior Member
    salaxi's Computer Details
    Windows 7
    Sony Vaio
    Intel Core i7 | 2.20GHz
    8.00
    AMD Radeon HD 7550M/7650M Graphics
    none
    PnP General Use
    Surveying
    salaxi's Discipline Details
    Geoinformatics , Geomatics & Land Surveying Engineer
    Surveying
    Mapping, Cartography, GIS, Land Surveying.
    AutoCAD 2008
    Jun 2013
    Greece
    15
    Exclamation I cannot change the LineType in my layers :(
    Hey guys its my first thread out here so i hope i will find help..Well i 've currently create several layers and after i change in one of 'em the linetype from continuous to a "Dashed" , every new layer i made had a "dashed" linetype and when i tried to change it back to default , it didnt.. Help!
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    When you create a new layer in Layer Manager, the new layer inherits the properties of the layer that's currently selected, so the first part does not sound unusual. I'm not sure what you mean by "change it back to default" because there is no "default" linetype for layers per se. Are you saying you can't use the Layer Manager to change the layer linetype back to Continuous?
    Junior Member
    Windows 7
    Sony Vaio
    8.00
    none
    PnP General Use
    Surveying
    Surveying
    AutoCAD 2008
    Jun 2013
    Greece
    15
    Unhappy ..
    Well actually i meant that , when i create a new layer, i cannot change the linetype. it seems that the default type of line is the continuous. From the time i made a layer with a dashed linetype, every new layer i'm trying to create, it have kinda inherit the property of a dashed linetype. And it is impossible to change it Sorry cannot describe it better...
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Quote Originally Posted by salaxi View Post
    ...And it is impossible to change it....
    I have never seen this behavior before.
    Please attach dwg file here that exhibits this behavior (can't change layer linetype after creating new layer).
    (If you had already done this - you would already have your solution and it is very likely no further word description would be needed.)
  5. #5
    Junior Member
    Windows 7
    Sony Vaio
    8.00
    none
    PnP General Use
    Surveying
    Surveying
    AutoCAD 2008
    Jun 2013
    Greece
    15
    elkd.dwg that is.
  6. #6
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    Sorry, I could not re-create the problem. The line types changed and stayed changed for me. However, I did notice that your line type scale is all over the place. If you are checking your line type visually on screen, after making a change in the layer manager, a line type scale of 0.02 is going to pretty much make the spaces in a dashed line invisible. I selected the whole drawing, changed the line type scale in the properties to 1.0 for all objects and the dashed lines suddenly appeared on screen.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  7. #7
    Junior Member
    Windows 7
    Sony Vaio
    8.00
    none
    PnP General Use
    Surveying
    Surveying
    AutoCAD 2008
    Jun 2013
    Greece
    15
    Thanks Dana I'll try it!
  1. Accessing a layers linetype name?
    By btraemoore in forum .NET, ObjectARX & VBA
    Last Post: 14th May 2013, 05:59 pm
  2. Change Linetype
    By jmerch in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Dec 2012, 09:29 am
  3. Replies: 4
    Last Post: 18th Jan 2011, 12:06 am
  4. cannot change linetype
    By shooter1 in forum AutoCAD Beginners' Area
    Last Post: 7th Dec 2010, 09:32 pm
  5. linetype and the layers
    By astrosfan in forum AutoCAD Beginners' Area
    Last Post: 22nd Sep 2008, 03:38 pm
Tags for this Thread
